Dash Bulb Replacement
Discussion in 'General Maverick/Comet' started by haroldbritton, Dec 4, 2006.
  1. haroldbritton
    haroldbritton Member
    Littleton CO
    1976 Mav 4 Dr 302 Hot
    I've read the threaded discussions on replacing the 194 bulbs in the front instrument dash panel, but my arms are too big to reach up under the dash to pinch the speedomenter cable and remove it. Suggestions? It is way up there.
    I want to install the brigher bulbs.
    Harold
  2. CornedBeef4.6L
    CornedBeef4.6L no longer here
    no longer here
    Find a smaller arm:D
    I work with a guy name Joe he is a big guy. 6'3" 260lbs and moster size hands. I help him get to hard to reach syuff like that. He helps me when I need a tall persons help. Great team work!!!!:clap:
  3. eddie1975
    eddie1975 Windsor Specialist
    Martinsburg, WV
    sold
    lubercation is key :evilsmile
  4. haroldbritton
    Littleton CO
    More help please.
    HB
  5. Jamie Miles
    If all else fails, you can disconnect the cable from the transmission (be prepared to loose some ATF) an pop the little clip loose from the frame so that you can pull the cluster out with the cable still attached to give you enough room to get it loose from the cluster. I had to do that with a Comet in the junkyard.
  6. haroldbritton
    Littleton CO
    thanks Jamie
    Good advice.
  7. courier11sec
    courier11sec Member
    Tucson, AZ
    Lance, that's bizarre. Until he left the shop a few months ago, I too worked with a big guy named Joe. He was about 6'3" and around 260lbs
