Dash Removal
Discussion in 'General Maverick/Comet' started by x72COMETx, May 21, 2019.
  1. x72COMETx
    x72COMETx Member
    Vallejo CA
    here is a dumb question, but is it possible to remove the dash completely with the windshield still in place?
  2. Acornridgeman
    Wisconsin
    Yes, but it gets very hard to get at the attachment points that are under the windshield rubber. You need to use something to pry up the rubber lip while you remove (or install) the fasteners. I put a dash into a car that had the windshield already installed. It was a pain and took all afternoon but I was able to do it.
  3. 71gold
    if it's an old windshield seal it will be almost impossible...:yup:
  4. x72COMETx
    x72COMETx Member
    Vallejo CA
    I actually replaced the windshield weather stripping about a year ago :slap:
  5. jbrich
    jbrich Johnny
    Atlanta
    72 Maverick
    When I installed the dash, I enlarged the screw holes in the firewall flange to allow the screws to slip through.
    Then I put clip nuts on the dash flange, and installed the screws from the bottom.
    The windshield is not a factor anymore.
    The screws can be accessed with everything except the a/c blower in place.
    CaptainComet likes this.
  6. 71gold
    then removing the windshield should be no problem...:huh:
