Decal Placement ... where's it go?
Discussion in 'Technical' started by dmhines, Dec 9, 2004.
  1. dmhines
    dmhines Dixie Maverick Boy
    Cumming, GA
    Does anyone have a 1971 Maverick with this type of Service Specs decal from the factory? IF so .. where was it located? I have seen it in 71 Mustangs on the radiator support but the support is not wide enough on a Maverick .... THanks ...
  2. Craig Selvey
    If nobody answers you in the next day or two....email me and I will look on my unmolsted 1971. It is also a factory V-8, AC car....if that matters.
  3. dmhines
    Cumming, GA
    Thanks ... My unmolested 71 didn't have it so I'm wondering if Ford used it in Mavericks ...
  4. rayzorsharp
    I honestly can't say I have ever seen that sticker on any of my 71's. Of course all of my engine compartments are modified so they don't have any stickers on them now anyway but I don't recall ever removing one like that.
  5. dmhines
    Cumming, GA
    Thanks Ray ...
    I place it all around and it just didn't look right anywhere ... the only place it kinda looked right was on the underside of the hood next to the latch ... This was my unmolested engine compartment ...
  6. littleredtoy
    littleredtoy Seth
    North Carolina, Triangle Area
    '74 Comet GT
    I think it goes on the valve cover, DM. Sorry I don't remember which side.
    I think that an orange sticker was on my driver's side cover, but that would
    be '74.
    Seth
  7. dmhines
    Cumming, GA
    I did put the emissions decal on the valve cover ... this is the service specs ... All MCA information says in 71 it went on the driver side shock tower. Obviously that's for a Mustang ..
  8. shaunh82
    shaunh82 Member
    Washington NJ
    71 Pinto sportsroof
    Dan,
    My 71 had it on the passenger side shock tower, about half way between the grease access, and the top of the tower, and the sticker wrapped around from the front to the inside of the tower. I think I might have a picture of it, I'll check when I get home, can't check the car, I took all the stickers off
    Shaun
  9. dmhines
    Cumming, GA
    Cool ... Thanks ...
  10. 2nd71Grabber
    2nd71Grabber Member
    I just looked at my unmolested 71 V8/auto/PS/AC car (I drove it to work today--JOY JOY!) and mine is on the underside of the hood to the passenger side of the latch. It is nboot totally flat, it wraps around that area on the cure a little (lengthwise).
  11. Mavaholic
    My 71 does not have one.
  12. Craig Selvey
    Here is where mine was located.
  13. MiteeMaverick
    MiteeMaverick Senior Member
    Jonesboro, AR
    1987 Mustang GT Convertible
    I looked at my 71 parts car and it is on the passenger side shock tower in the front, the same as the pic in the ealier post. Looking at the front mine is about 1/2 inch higher on the right, the guy must have not worn his glasses that day.
  14. dmhines
    Cumming, GA
    Thanks Craig!
  15. shaunh82
    shaunh82 Member
    Washington NJ
    71 Pinto sportsroof
    yep, mine's the same, I can post the pic if you really want, but I think craig stole my picture :p
