Decoding engine stamp
Discussion in 'General Maverick/Comet' started by cardstars, Apr 21, 2011.
  1. cardstars
    cardstars Member
    Minneapolis
    Hello,
    Just hoping someone can help me out. Purchased a stroker kit for my 71 gt comet. Its not spec'ing out and we are now wondering if the engine was swapped at some point.
    Code is: 1K55063
    Anyone know if this is really a 302 from 1971?
  2. rthomas771
    Looks like a Vin number...not a casting number
  3. jmgford
    jmgford Member
    Iowa
    Blocks are stamped with the first 2 and last 6 VIN numbers. The stampings are usually shallow and it is common to not see all the digits. It indicates this engine is from a 1971 Kansas City -built Ford prodcut with a VIN ending in 55063x. Check your VIN. It's probably the original motor.
    What do you mean, "Its not spec'ing out"?
  4. cardstars
    cardstars Member
    Minneapolis
    All my main bearings are very tight. Tighter than what clevite says. The housing bores are 0.0008" smaller than the housing bore recommendation. Should I line hone it to spec or use and extra clearance bearing?
