Demensions for a 1970 Maverick
Discussion in 'Technical' started by DDCrunch, Feb 5, 2004.
  1. DDCrunch
    DDCrunch Member
    USA
    Dies anyone know the engine compartment demensions for a 1970 Maverick or the largest sized engine that could be put in threre without having to refurbish underneath the hood.
  2. jpollard
    jpollard Member
    Montana
    1977 Factory 302 Mav. 1970 Cougar Eliminator, 1975 302 Grabber, 1976 4door 200...and still looking
    The 351W and 351C are about the largest motors you can get in it without any or just minor mods. Mods usually consist of dinging in a shock tower or firewall to get headers to fit. If you use stock exhaust manifolds you should be able to get away with no modifications. A friend of mine put a 351C in with headers and did not have to dent or ding anything. He used a set of 10 piece headers made for an early (66) Mustang. Dont remember exactly what they were. If I remember right...the heads were about touching the shock towers. What are you trying to do with the car? 302's fit great and can be stroked to produce tons of power and you can usually still change the spark plugs. Good luck with whatever you decide.
    JP
  3. Maverick Guy
    Maverick Guy Maverick Enthusiast
    NE Ohio
    Jpollard, you got my interest . . . if can find out what kind of headers on that 351C, I would appreciate. It's kinda of a dream mod for me, I know Mavericks never came with 351, but I have always associated the 70's with those Clevelands.
  4. DDCrunch
    DDCrunch Member
    USA
    So would you recomend going with the sbf 302 instead of the 351?
  5. jpollard
    jpollard Member
    Montana
    I will make a call this weekend and try to find out the headers he used.
    I guess for ease of maintenance and installation I would go with the 302...If you want the most performance, a 351 would probably run better. Although if you stroke a 302 you will have the ease and performance. Of course you can also stroke a 351!! Its kind of endless...it depends on your budget and what you want to do with the car. If you already have a 302 and are looking for a good running street machine, I guess I would have to recommend the 302. Ultimately it is up to you. Anyone else have any suggestions that might help make up his mind??
