difference between an L6 200 and 250
Discussion in 'Cosmetic' started by Borikuapr, Apr 23, 2019.
  1. Borikuapr
    Borikuapr Member
    Puerto Rico,USA
    Maverick 1977
    hello friend how can I tell the difference between an L6 200 and 250 I would appreciate any help, thanks
  2. Krazy Comet
    Easiest way is look at starter position. A 200 has a high mount, three bolt starter. The 250 starter is low, approx even with oil pan rail.
    Fifth digit of VIN is T if 200, L 250.
  3. rthomas771
    250 has 4 bolt water pump...200 has 3 bolts. Late 200's have low mount starter same as the 250
  4. Krazy Comet
    That didn't happen until the '80s and are not directly interchangeable with the early 200.
  5. Borikuapr
    Borikuapr Member
    Puerto Rico,USA
    Maverick 1977
    thank you guys for your answers they helped me a lot
