disc brake article i found
Discussion in 'Technical' started by john T, Dec 2, 2010.
  1. john T
    john T Member
    coalinga CA
    72 maverick grabber
  2. RMiller
    RMiller My name is Rick
    Kennewick, WA
    1971 Maverick Grabber
    Can't see any reason it wouldn't work, if mine wasn't already converted I would give this serious thought.
  3. RMiller
    Kennewick, WA
  4. brainsboy
    brainsboy Member
    Tampa
    Great conversion but I wouldnt feel confortable riding on home made welded brakets.
  5. maverick75
    I would, If I welded them. I could have sworn someone did this on a maverick, but I was wrong they just upgraded the calipers.
  6. john T
    john T Member
    coalinga CA
    72 maverick grabber
    i personally wouldnt use grade 8 bolts id go for 12s or cat bolts. just my personal preference. anyway that i could keep my rims theyre 14s the id is 13, depth is 3 1/2.
    i really like the rims i have and the guy that i bought it from told me that theyre rare (which im not too sure about) that and i dont want to spend even more money
  7. john T
    john T Member
    coalinga CA
    72 maverick grabber
    i read through the comments you dont actually have to weld on the dog leg brace as he calls it. his engineer buddy said 2 bolts would be sufficient. i would put the extra bracket on it anyway for piece of mind. but other than that that was the only welding involved. he welded on the spacers but you dont have to the bolts will hold the spacers in place i imagine it would just make putting the brackets on easier.
  8. RMiller
    Kennewick, WA
    Grade 8 is all the factory used, I wouldn't think twice about it myself.
  9. john T
    john T Member
    coalinga CA
    72 maverick grabber
    just orderd the granada rotors, brake lines fittings and the mounting plate from speedway. got the rotors at autozone for 46.99 each
    total its about 200 for all the stuff at autozone and i spent 80 at speedway.
    fun fact a reman master cylinder for a 75 maverick is 10 bucks with a lifetime warrant new its like 99
  10. john T
    john T Member
    coalinga CA
    72 maverick grabber
    how does the rotor fit on the spindle? is it tight or supposed to be loose?
    i ordered granada rotors but i have the stock 72 drum spindles. do i need to order neew granada spindles?
  11. PaulS
    The inner bearing (and that part of the spindle) is larger on the Granada than on the Maverick. I would take my old bearing and one for the Granada to a bearing house and see if they have a bearing with the small inside diameter and the larger outside diameter. Then you just have to buy two new bearings instead of new spindles.
    It may or may not be available but it is worth trying.
  12. mercgt73
    mercgt73 Member
    I have disc brakes with drum spindles. But mine are 2005-10 Mustang GT discs, all the way around. No welding and the lower brake brackets are continuous around the spindle.
    http://mmb.maverick.to/showpost.php?p=652598&postcount=68
    The design is not my original, saw it here: http://www.mustangsteve.com/cobrabrakes.html
  13. Mike Evans
    Mike Evans Member
    Versailles Kentucky
    1972 Maverick Restomod and 1966 mustang restomod
    The mustang steve parts really work. I put 2008 GT mustang brakes on a Maverick spindle. Fits like a glove. The rear kits for Cobra brake conversion works on 8 and 9 inch rear ends also. Have to use 17 inch wheels.
  14. john T
    john T Member
    coalinga CA
    72 maverick grabber
    maverick and granada wheel bearings and seals are the same just came from autozone same part numbers all around, seals and bearings are the same. ill find out if it works soon enough. sorry to bring up an old thread but i just ran into a little bit of money so im trying to get my car back on the ground and running
  15. injectedmav
    injectedmav Member
    Georgia
    I'm running welded brackets and grade 8 bolts, no problem. I'm also running drum brake hubs on a Granada disc brake spindle, I thought they were interchangeable but I may be wrong. I did my conversion 3 yrs ago and only documented rotor sizes... oops.
