Disc Brake M/C
Discussion in 'Technical' started by rickm, Nov 29, 2010.
  1. rickm
    rickm Member
    Owosso Mi
    Can anyone tell me what M/C I should use with the Granada brake swap. I know Granada but will others work better because of port sizes ? I call around and I find M/C's for power systems but not for manual. I will be using a porportioning valve on the rear line. Thanks Rick
  2. facelessnumber
    facelessnumber Drew Pittman
    Memphis, TN
    '71 Grabber
    Simplest would probably be a master cylinder for a '75 up Maverick with disc brakes. I'm using a '96 Explorer part for mine because I have four discs and I decided to use one for a 4-disc application. '91ish Ranger/Explorer is another one that fits, and it's for disc/drum. I've run all three of these and they all work fine.
  3. rickm
    rickm Member
    Owosso Mi
    Hey faceless you have a PM.
  4. rickm
    rickm Member
    Owosso Mi
    Has anyone used a power MC for their manual brakes ? The only thing different is the port sizes ( by that I mean thread size) and that I was told was so there was no mistake at the factory. If I see this right you only need to look at bore size and rod length ? :hmmm: :hmmm: Rick
  5. starsky74
    starsky74 Technician
    Hackberry Louisiana
    check out scoopers, he has a wilwood that i am uber jealous of. there is an old thread about this
  6. Earl Branham
    Lugoff, SC
    I used one from a '91 Dodge Dakota. Had to file the mount holes a bit, but fit nice, and works great. Looks better and frees up a little space.
  7. mavgrab302
    If you use a 75 and up M/C make sure you save the pedal rod, I went though all the years trying to get the right one they where all to long... You will have to shorten it or do as I did and buy an adjustable one....
  8. rickm
    rickm Member
    Owosso Mi
    Thanks Ken
  9. 71nogo
    71nogo Member
    tucson,az.
    71 grabber
    do you have a picture of that?
  10. Earl Branham
    Lugoff, SC
    I will have to get you a couple. In this pic, you can see the m/c, but not how it mounts, etc. I'll get some today and send them along.
  11. 71nogo
    71nogo Member
    tucson,az.
    71 grabber
    that would be great. I want to free up some space as well.
  12. Earl Branham
    Lugoff, SC
    Got you 3 pics of he m/c and 1 of the Wilwood distribution block/adjustable rear pressure valve/brake light switch. Hope this answers your questions.:)
  13. 71nogo
    71nogo Member
    tucson,az.
    71 grabber
    yes and no! what did that set up cost you. and how did you wire the brake light switch?
  14. rickm
    rickm Member
    Owosso Mi
    Earl, You did say that MC came from a dakota ? I look at rockauto and all the 91 Dakotas have 2 caps ? What rod did you use ? Can the rod fall out ? If not did you have to put a stop in for your pedal ? Hope your OK with a few questions, Oh and is that steel tubing or that newer flexable tubing ? Thank you VERY much for your input Rick
  15. facelessnumber
    Memphis, TN
    '71 Grabber
    That looks just like the Ranger/Explorer master cylinder to me...
