disc brakes?
Discussion in 'General Maverick/Comet' started by 73 maverick man, Jan 2, 2009.
  1. 73 maverick man
    73 maverick man Member
    Pennsylvania
    73 maverick
    I have a 73 Maverick and all 4 wheels have drum brakes i would like to put disc brakes on the front. Will i have to change the master cylinder? If so will the master cylinder i need still work with the booster i already have?
  2. rayzorsharp
    Typically the reservoir on the master cylinder for the front disc is much larger than one for drums. Disc brakes require more fluid to operate that drums do and your fluid level drops quite a bit as your discs wear out. A drum master cylinder should work but you would always have to worry about running the reservoir too low and getting air in the system or even worse, having the brakes fail on you. If both reservoirs on your m/c are the same size, yes, I would change it out. The booster should work fine with either.
  3. Alan
    Alan Member
    Vancouver, Wa
    1971 Mercury Comet
    This might be a little off-topic, but additionally what you could do when you make the drum--->disc transition, is go ahead and make the jump to 5-lug wheels, since you've already got the rest of that stuff off anyway. Kill two birds with one stone.
    Apologies in advance if you already knew this/were already planning to do this.
  4. rayzorsharp
    I'm guessing he already has 5-lug wheels.
  5. CaptainComet
    Ought to be able to get the right MC pretty easily still from a local parts house cheap ...
  6. Jamie Miles
    I'm running a master cylinder (and proportioning valve) for a 4 wheel drum '73 on my '72 with front disc brakes. I've got about 28,000 miles on the setup with no problem. I always check my brake fluid level when I change the oil (somewhere around 4,500 miles usually). It's been a little low a couple of times, but not dangerously low.
    All '73+ Mavericks and Comets are 5 lug.
