Disposing of used brake fluid...in oil recycle?
Discussion in 'General Maverick/Comet' started by scooper77515, Jul 17, 2014.
  1. scooper77515
    What is the accepted manner for disposing of used/dirty brake fluid?
    Is it ok to add to my recycled oil container?
  2. Dave B
    All depends on where you take it, some places will just take fluids in general, so want them labeled and separated. I know here I can take anything to the hazardous waste depot, no questions asked.
  3. blugene
    At Pep Boys we only separated coolant from all others.
  4. scooper77515
    I have no idea what brake fluid is made of...I know coolant is alcohol/water based, and would never mix it with oil.
    If the brake fluid is petroleum-based, it should mix right in with the used oil and recycle with it.
    But I don't want to pour it in, have it not mix, and end up with 5 gallons of used oil I cannot get rid of.
  5. MaverickDan
    Midlothian, VA.
    73 Maverick 4dr
    We dispose of brake fluid with oil at my work. Like said above coolant is disposed only differently.
  6. Mavman72
    We have a waste oil heater at work. Brake fluid/trans fluid/motor oil...It all goes in the holding tank...It all burns...The heater dont care. You can mix it with the waste oil...It wont care either.
  7. simple man
    simple man Member
    Bunnell,Florida
    Try mixing a little brake fluid with a little oil. If they mix, you're all set! If not, I know it burns. :)
  8. scooper77515
    Really? It burns?
    I could add it to the burn barrel, if so. And if it does not mix with the oil.
  9. scooper77515
    I added some non-synthetic gear oil, it floated on top of the brake fluid. Shook it up a bit, and it quickly separated, with the oil on top.
    Will try to burn a small amount tomorrow, if it stops raining.
    I only have about a pint, so not a large quantity.
  10. junrai
    junrai Member
    rancho cordova ca
    sounds like good fuel for a burn barrel
  11. Dave B
    It'll mix, unless it's dot 5.
  12. scooper77515
    Dot 3. I will check on it tomorrow.
    Probably dump it in the oil, anyway. It isn't very much. Wouldn't be able to see it in a 5 gallon bucket of oil.
  13. CaptainComet
    Brake fluid is good for stripping some paints, but I have never tried used-up nasty brake fluid. Mostly it was containers that had been opened and then sat for months. You don't want to use brake fluid that has had the seal broken more than 6 months earlier because it starts collecting small amounts of water in it.
