Distance between steering knuckles?
Discussion in 'Technical' started by ryanb, Oct 14, 2015.
  1. ryanb
    ryanb Member
    Portland, Oregon
    '72 2D Maverick, '85 F150 Short Wide, '07 Husqvarna SMR450, 2015 Yama FZ09
    I probably don't have the correct terminology but what I am looking for is a loose approximation of the distance between steering knuckles (where the tie rod bolts through) on the spindles. I'm trying to work out a good sizse for a rack and pinion to source. I'm planning on ditching the factory box and fabbing up a mount and steering linkage for a rack.
    Pinto racks are 45" OAL and I can get one brand new for under $100. How hard could it really be to make the mounts and get the geometry right. I just need to make sure the rack is the same steering configuration (rear steer).
    Anybody willing to take a measurement for me or have the number off the top of their head?
    -Ryan
  2. Krazy Comet
    Referring back to a post I made when rebuilding my front suspension, it's approx 44"...
  3. mavdog71
    mavdog71 Member
    Moreno Valley, CA
    '71 Maverick Grabber
    A Pinto rack CANNOT be used .Its a front steer rack .You are going to need a rear steer rack . You can check with 55 crown vic on this board he has the info you need.
    Krazy Comet likes this.
  4. ryanb
    ryanb Member
    Portland, Oregon
    Roger, I'll look him up then, thanks.
