Does my car have duraspark?
Discussion in 'Technical' started by mashori, Jun 28, 2009.
  1. mashori
    mashori Member
    San Diego, Ca
    1971 V8 Maverick
    I'm confused about some stuff on my car. So when I had a V8 installed from my old I6 the mechanic got rid of the points. I know there is a coil on my engine (I can see it). My question is, does my car have duraspark?
    I'm going to be replacing my distributor because the vacuum probably is bad on it and Craig S suggested I might as well replace the whole distributor for a little bit more $.
    I found this one from kragen, should work right?
    here is a pic of what might be relevant:
    http://picasaweb.google.com/lh/photo/L_5ZStmH0wXOPTuWw76idg?feat=directlink
    http://picasaweb.google.com/lh/photo/UfbVaybMq3Tlmgu5nQGZkg?feat=directlink
  2. Mavaholic
    Dont look like you have it to me.
  3. blugene
    Looks like points to me by looking at the cap. The Kragen link takes me to a request for a zip code.
  4. Bubba Bob
    Bubba Bob Member
    Auburn, AL
    Take the cap off. If it has the breaker point, you'll know your answer.
    Breaker Point - (letter B)
    EDIT -
    Besides that, I don't see an ignition module anywhere for the duraspark.
  5. dmhines
    dmhines Dixie Maverick Boy
    Cumming, GA
    If you don't have a silver box on your firewall that says DURASPARK on it and connected to your coil ... you don't have it ..
  6. greasemonkey
    greasemonkey Burnin corn
    Sedalia,MO
  7. mashori
    mashori Member
    San Diego, Ca
    1971 V8 Maverick
  8. mashori
    mashori Member
    San Diego, Ca
    1971 V8 Maverick
  9. cdeal28078
    cdeal28078 Member
    North Carolina
    71 F100
    NOT a Dura-Spark but it IS an Electronic ignition. Some sort of aftermarket. Looks like a Pertronics to me but I have only installed 1 of those. Don't care much for them but they work alright.
    The box under the starter Solenoid does look like an ignition box. Never seen one like it though.
    Whatever you have it is far better than points
    clint
  10. rthomas771
  11. sierra grabber
    sierra grabber Certifiable
    northern nevada
  12. blugene
    Agreed. It's a Pertronix ignition and a voltage regulator under the starter solenoid/relay. What is the the reason for the inquiries, I guess I forgot.:huh:
