don't know if...
Discussion in 'General Maverick/Comet' started by 71gold, Feb 22, 2020.
  1. 71gold
    I'm lucky or unlucky.
    went to fire up my new EFI system and "no start".
    the diagnostic screen on my phone app shows "no fuel pressure".
    I can hear "pump running" in the tank.
    I "clamped off the return line" hit the key and no pressure reading.
    I"removed the line to the fuel rail" no fuel came out with pump running.
    the pump is controlled by the ECM so my Buddy suggested that "the ECM is bad" or not getting reading from fuel pressure sensor. I think it's good because it's turning the pump on.
    I'm draining the tank as we speak. I'm thinking the pickup tube on the intank pump has fallen off.
    that's the "bad luck"
    the "good luck"
    all this is happening with my car , in my shop, on my lift...not on the side of the road hundreds of miles from home...:thumbs2:
    Earl Branham, Crazy Larry and mojo like this.
  2. Krazy Comet
    If pump is running, isn't ECM at fault.
    Most likely problem in tank which isn't likely pump.
    I have seen one pump blow out the pressure port but still ran.
    All the problems you have make me look fondly at a old Holley carb & even a set of points.
    stumanchu and BBMS18 like this.
  3. cyclonewill
    cyclonewill Member
    SandSprings, Oklahoma
    How do you get so lucky? My stuff always breaks 200+ miles from home.
  4. 71gold
    pulled the pump today...it was bad. had ordered a new one just in case. have everything ready to go back together tomorrow...:bouncy:
    maverick600 and ike72com like this.
  5. 71gold
    It's alive...
    replaced the pump and it fired right up...:thumbs2:
  6. m in sc
    m in sc Member
    rock hill sc
    yup. your car loves you.
  7. Krazy Comet
    Reminds me of my ex wife. :slap:
  8. CA189HJN
    CA189HJN Robert Couse-Baker
    Sacramento, California
    1973 Ford Maverick 4-door 302
    Just because it's a new part doesn't mean it ain't broke.
  9. stumanchu
    stumanchu Stuart
    Portland, OR
    Lol....BTW Frank, I think your car will treat you better after it gets painted.
  10. 71gold
    :slap:...I had it painted, just the same colors and cleared.
  11. stumanchu
    stumanchu Stuart
    Portland, OR
    Well then, I suppose straight, shiny, and rust free are happy car things.....hmmmmm, my car gets to live under a sheet of plastic all winter so I better shut up.
