Door Latches
Discussion in 'Parts Interchange' started by mav1970, Aug 8, 2012.
  1. mav1970
    Does anyone know if there are reproduction Mustang door latches that are compatable with the ones on a Maverick?
  2. Cruzin Illusion
    Cruzin Illusion Enigma
    Commerce City, Colorado
    1972 Grabber
    Here is the part numbers of the door latches I used on my 72.
    LH C9AZ-6221813A
    RH C9AZ-6221812A
    They were a perfect fit and of good quality. I believe they are for a mustang the is the same part used on the maverick.
  3. 71gold
    may want to put this in...http://mmb.maverick.to/forumdisplay.php?f=5
    ...:yup:...
  4. Dave B
    So, the "A" in C9AZ, usually means it's a generic part, used on a number of cars.
    I always thought people knew they were the same...
  5. mav1970
    What year Mustang would these latches be ordered for? I found that CJ Pony Parts sells latches so I'm sure all of the other Mustang parts houses have them but they use their own part numbers.
    Also what about Mustang striker plates? What year Mustang would be a direct fit for those?
    Thanks, Bob
  6. mav1970
  7. CaptainComet
    "C9 ..." should mean 1969. First character is decade ... C= 1960s, D= 1970s, etc ...
    The second character is generally the first year a part was put into use in any Ford car ... and usually remains the same until a revision comes along.
  8. maverick1970
    maverick1970 MCG State Rep
    Missouri
    From the Autokrafters website
    Part Number: C9AZ-6221813A
    Fits 1969-70 Full size Ford / Mercury; 1969-70 Fairlane / Torino; 1969-70 Mustang; 1968-70 Cougar; 1970-72 Maverick; 1969-70 Falcon; 1968 Comet with vacuum or door ajar system; 1969-70 Comet / Montego; 1968-70 Meteor. This door latch assembly has a 1 1/4 inch long lock rod shaft with two holes in it. This is an excellent reproduction and fits the left side. For screws see part #AK400, for lock rod retainer see part #C5AZ-6221952A. This door latch has a short (1 1/4" with 2 holes) lock rod shaft.
    Part Number: C9AZ-6221812A
    Fits 1969-70 Full size Ford / Mercury; 1969-70 Fairlane / Torino; 1969-70 Mustang; 1968-70 Cougar; 1970-72 Maverick; 1969-70 Falcon; 1968 Comet with vacuum or door ajar system; 1969-70 Comet / Montego; 1968-70 Meteor. This door latch assembly has a 1 1/4 inch long lock rod shaft with two holes in it. This is an excellent reproduction and fits the right side. For screws see part #AK400, for lock rod retainer see part #C5AZ-6221952A. This door latch has a short (1 1/4" with 2 holes) lock rod shaft
  9. mav1970
    Thanks for the info - I didn't realize that Autokrafters was using those Ford part numbers - are the matching striker plates, that will fit a Maverick, also from a 69-70 Mustang?
  10. maverick1970
    Missouri
    STRIKER PLATE - LH OR RH$14.95 USD[​IMG]Part Number: C5AZ-6222008A
    - Fits 1967-70 Cougar - Mustang; 1965-70 Galaxie; 1966-71 Fairlane; 1970-77 Maverick; 1968-77 Bronco; 1965-71 Thunderbird. Door Striker Plate, left or right. Includes striker plate, shim, screws. Sold individually.
  11. mav1970
    Thanks tons :tiphat:
  12. car-nut
    car-nut Glenn
    conn.
    Funny this should pop up today. Cobra Automotive is a customer of mine. I was there helping them match a color today and I asked if they had any used parts for mock up purposes. They do keep parts around just for that reason. So I grabbed a door striker, latch and outside door handle for a 65-66 Mustang. I just checked them against my Maverick and they are exact to what I have.
    I was surprised, very good news for us.
  13. CaptainComet
    With regard to the door handles ... some folks here have been saying the 67-68 Mustang piece is "the right one", but that something with the internal works is a bit different. Don't know much more than that ... maybe a part swap internally helps.
    I just scored the best Mav door handles I have ever seen .... whoo-hoo ... just in time too. Working on my drivers door.
  14. A_Bartle
    A_Bartle Stallion Dreamer
    Michigan's Thumb
    1976 Yellow 2-door Maverick
    I put the Mustang door handles on both of my cars, however, I found the repros did a poor job with the push button. It was too small and felt loose in there (poor reverse engineering, lol). Someone on this forum (might have been Dan Starnes, not sure now) told me that you could use the button from the old factory door handles, and that is what I did. They fit very nicely, but you have to make some small adjustments to the connecting rod after you do this (it's been a while, but I think I had to adjust the rod to be a tad bit longer inside the door).
  15. Dave B
    The inner lever on some repops is different, but swaps easily from the Maverick handle, also the button on some repops is crappy, all depends on what brand you buy.
