DOUBLE-JEOPARDY question of da day: The Ford Dash Squeak...
Discussion in 'General Maverick/Comet' started by whisky, Feb 26, 2009.
  1. whisky
    whisky Whisky
    Vancouver, BC
    72 Comet I-6, 72 Comet V-8
    Came up in a thread again... I meant to ask this here earlier...
    Old Mustangs and our cars suffer from this malady... seems to come from under the right side of the car or behind the dash.
    Mine is intermittent - some days it happens at EVERY SINGLE STOP, sometimes only going over speed bumps, then nothing at all for weeks at a time so I forget about it.
    So WHAT IS... the Ford Dash Squeak?
    Whiskeee
  2. hacksaw415
    hacksaw415 Member
    slum bum frisco
    75 booger green mav
    ive been told its caused by bad mufler bearings used in the late 60's and early 70's. Check em out, hope i helped.
  3. whisky
    whisky Whisky
    Vancouver, BC
    What's a muffler bearing and does it need grease? heh... uh... :cool:
    I always thought of exhaust as the culprit but we changed a few systems out and the squeaking seems to come from some place forward of that (unless the acoustics of our cars are SO BAD that's what it is...). More up in the firewall.
    Methinks frame-flexing over speed bumps... maybe the dashboard itself... and they didn't use styrofoam back in those days because that's what it sounds like. Squeaky styrofoam.
  4. Craig Selvey
    Upper A-arm bushings.
  5. rayzorsharp
    Bingo! Mavericks are notorious for this.
  6. Bob Wiken
    Fayetteville, Arkansas
    Flex point in the upper right corner of your flux capacitor.
  7. maverick1970
    maverick1970 MCG State Rep
    Missouri
    Loose nut behind the wheel! :D
    I agree with the upper a-arm bushings.
  8. cjtorinoman
    cjtorinoman Member
    chesapeake va
    If you are talking suspension squeak then as FORD TECH for 20 years all those hacked up shock towers to grease the control arms are in vain. It is the non greaseable spring perch/saddle on top of the control arm that the coil spring rides on that is of corse if you are talking suspension squeak.
  9. rayzorsharp
    Sorry but I have to disagree with you. I have had to install grease fittings in way to many Mavericks to get rid of the typical front end squeak on these cars and I have owned about 40 different ones, nine presently. I have never had to replace the upper perch to do it. Not saying it won't cause a squeak but it's way more common for the upper bushings (no grease fittings) to dry out and cause it. They even make a kit with a tool and 90% fittings to keep from cutting holes in the shock towers for this problem.
  10. sierra grabber
    sierra grabber Certifiable
    northern nevada
    im with ray on this, mustangs and cougars do it also. i have also found that just pushing grease into the bolt holes does fix it temporarily if you dont want to put in the grease fittings.
  11. cjtorinoman
    cjtorinoman Member
    chesapeake va
    So you have 40 year old spring perches because they don't go bad and make noise?
  12. rayzorsharp
    No, I simply stated that I've never had to replace the perch to get rid of the squeak caused by the dried out control arm bushings. I do usually replace the perches when I do a rebuild though.
  13. Demmitt
    Demmitt nutz and boltz
    Sandsprings, Oklahoma,
    1976 2 door, 1969.5 2 DOOR
    same prob
    turns out the upper a arms mounting bolt holes were oblong from ware (wallerd out)
  14. Mavman72
    Nah...its from squeaky paint...
  15. sierra grabber
    northern nevada
    actually, the ones on my wifes 68 cougar are still on there and still stock.The current owner is a licensed mechanic and is restoring it for show. if they are kept lubed and the car is driven fairly normal they last pretty well. the grabber on the other hand, i had to replace them despite proper maintenance. probably something to do with how i drive it.....hehe
