Doug thorley headers
Discussion in 'Technical' started by Danielmaverick, Aug 24, 2017.
  1. Danielmaverick
    Danielmaverick Member
    Earth
    1970 ford maverick
    I know that there are threads out there about Doug thorley headers but they don't show any solutions that fix my issue. Is there anyone with this exact problem that has a solution with pictures. I have taken the car to many shops to get the exhaust done but everyone says they can't do it. I don't know much about exhaust but I thought a 90 degree bend to a 45 would be fine to get pipes to clear the pitman arm.
  2. Crazy Larry
    Crazy Larry Member
    Wichita, Kansas
    Unfortunately, the only solution is custom headers for a Maverick (expensive). It's sad that no one makes shorty headers that fit a Maverick/Comet really well. There are full-length headers that fit really well.
  3. Maverocket
    Maverocket Bob Williams
    Northwest
    69.5 Mav, 62 F100 unibody
    I think Krazy Comet (Tom) has worked through the Thorley issues on his car. You may try to message him.
  4. Danielmaverick
    Earth
    1970 ford maverick
    Thanks
  5. Craig Selvey
    I have the Doug Thorley shorties and I have NO issues. I have power steering, which I would think would have even less room.
  6. Craig Selvey
    More pictures
    jasonwthompson likes this.
  7. jasonwthompson
    jasonwthompson Member
    Carrollton TX
  8. 71Mavrk
    71Mavrk Member
    Nevada
  9. Danielmaverick
    Earth
    1970 ford maverick
  10. Danielmaverick
    Earth
    1970 ford maverick
    Maybe it's because I have a manual transmission it looks like Criag has way more space in between the pitman arm and bell housing.
  11. Krazy Comet
    His apparently has a thinner flange(or larger opening?) that allows the pipe to swivel away from the pitman arm... Mine wound up similar to Micah's...
    If the left outlet had been better centered and extension possibly curved a bit these would be a breeze, as they are I'd never recommend a set to anyone...
    Crazy Larry likes this.
  12. Danielmaverick
    Earth
    1970 ford maverick
  13. Danielmaverick
    Earth
    1970 ford maverick
    I'm just going to remove the Doug thorleys and reinstall my long tube hooker headers. They are not ceramic but they will do for now until I get the ceramic version.
    Thanks to everyone
  14. Craig Selvey
    I think it is 2 1/4". I can't find the specs right now.
    I didn't cut anything off of the headers.
  15. Danielmaverick
    Earth
    1970 ford maverick
    Spilled some oil on my headers after changing them out. Now car smokes when running how long until it stops?
