Driveline swap
Discussion in 'Technical' started by Campmaverick, May 22, 2022.
  1. Campmaverick
    Campmaverick Member
    Reedley ca
    1972 Maverick grabber
    I was wondering if I can use my 6 cylinder driveline off my 200 inline motor I know I will need the change bell-housing and torque converter and flex plate I have a weight it looks like near the front yoke as I remember my v8 72 with c4 didn’t have the weight on the yoke shaft . Thanks
  2. 71gold
    if it's a disk around the driveshaft it's a vibration dampener. most take it off, the rubber center breaks down.
  3. Campmaverick
    Campmaverick Member
    Reedley ca
    Yeah I believe it’s the disc does the whole thing come completely off or do I need to cut it off thanks for your reply
  4. Jaybee
    Jaybee Member
    Hampton Roads, VA
    1974 Maverick
    Can you remove the shaft from the rear yoke and slip it off that way?
