driver side sport mirror (Glass)
Discussion in 'Technical' started by Rickeeling, Jan 28, 2015.
  1. Rickeeling
    Rickeeling Member
    Clarksville Tn.
    2 door 73 Maverick with a 302
    Really don't know if I should post this on the technical post or general post, its not a technical question, so her I go.,,,, the mirror (glass) that I bought from Melvin's for the driver side sport mirror, is smaller then what came out. It is, on the other hand the same size as the passenger side. My question is,,, did Melvin's send me the wrong one or is there indeed a size difference. ?
  2. rthomas771
    I know there's a top and bottom when replacing the lens. If you get it backwards the corners on the sides won't look right. This is why the Dorman replacement lens has a mirrored finish on both sides of the glass so it can fit either side...so they clam. I do know the Dorman lens fits the passenger's side but their quality is another story.
  3. BKelley
    BKelley Comet Enthusiast
    Stone Mountain, Ga
    "72" Comet GT
    Yes, Melvins sent you the wrong lenses.. Early 69 Fords and prior, both lenses were the same size, begining in late 69 until mid to late 70's the drivers side mirror glass was a little wider than the pass. side.
  4. Rickeeling
    Rickeeling Member
    Clarksville Tn.
    Thanks gentlemen, Looks like I will be giving Melvin's a call tomorrow. Just wanted to make sure.
  5. safado
    safado Member
    West Phoenix, AZ
    Is there someone that "rebuilds" the sport mirrors??.. just closed the pass door and glass fell out...
  6. rthomas771
    Passenger's side is a piece of cake...if you can get the two screws out holding the lens assembly to the head without destroying the screw head. You might want to remove the mirror from the door and be sure to use a good fitting quality screwdriver to remove these screws or you will mess up the screw head. See http://1bad6t.com/Maverick/maverick_50.html
  7. socalcomet
    socalcomet Member
    Menifee, California
    1974 Comet
    This is a video from WCCC...
