dual exhaust?
Discussion in 'Technical' started by BrianB, Jan 17, 2011.
  1. BrianB
    BrianB Member
    1973 Maverick
    is it true no maverick came standard with dual exhaust?
  2. ratio411
    ratio411 Member
    Pensacola
    1972 Sprint and 1975 Maverick
    It's true....
  3. BrianB
    BrianB Member
    1973 Maverick
    oh cool i guess the previous owner did more work then i thought
  4. injectedmav
    injectedmav Member
    Georgia
    so true, in fact, that the bottom of the car makes it a challenge for anyone other than a really good exhaust fabricator, if you want tail pipes that is.
  5. ptpdub
    ptpdub Member
    canada Sk.
    i know this is true because i am not a "really good exhaust fabricator", and as such - i have turn downs in front of my diff! sigh. i got to get back out there. i want tail pipes.
  6. BrianB
    BrianB Member
    1973 Maverick
    it doesn't have tail pipe it stops half way down the car it sounds nice though little loud inside the car but i dont mind =)
  7. scooper77515
    Mine dump just at the axle, and it is "a little loud inside the car".
    I wouldn't mind moving some of that sound outward, exiting just in front of the wheels, if possible. I liked that setup with side pipes and side exit, but the CalTracs sorta get in the way.
    Here is a picture of where i just had to cut my exhaust off both sides to install the CalTracs and subframe connectors.
    I might be able to squeeze by them if I tried.
  8. ratio411
    ratio411 Member
    Pensacola
    Do the Stang gas tank mod and you'll have plenty of room on both sides to run exhaust out the back. It can be done with the stock tank, but it's a pain, and it will always be scary close to the tank on that one side. If you use a Stang tank, centered up, you can use off the shelf Stang exhaust kits.
  9. maverick75
    If you ever decide to get tailpipes take it down to De Anza exhaust on 14th and Market. They do awesome work at very affordable prices. They have done exhaust systems for a bunch of Magazines like Hot Rod, car craft and several street rod ones.
