Dual outlet exhaust manifold for small six
Discussion in 'Technical' started by PeytonMaterne, Dec 27, 2004.
  1. PeytonMaterne
    PeytonMaterne Member
    Has anyone tried to make one? Do all the manifolds have the dump in the same location? I know they make dual outlet headers but they're out of my price range. What is the outlet diameter for the 250s(are they larger than the 170-200)? Peyton in SE Ohio
  2. Old Guy
    Old Guy Member
    You maybe able to "split the manifold" as we did way back when. Consists of taking a piece of metal plate to fit, and welding it into the opening to block off three cyl. then in that same section, cut a hole in the bottom of the manifold and weld in a exhaust pipe connection. Back then we just used a pipe nipple around 1 1/2 in diam. and after welding, attached a lenght of the infamous "flex pipe" held on with a hose clamp and routed down to a "glass pack muffler". Now days, should be able to get the right connection and have a custom pipe made. Mucho better setup.
