"Dynamat" alternatives?
Discussion in 'Technical' started by Popbumper, Jul 8, 2008.
  1. Popbumper
    Popbumper PINTO unashamed
    Dallas, Texas
    Hi guys:
    I am wanting to line floor pans with new sound/heat deadening material after POR-15 treatments. As opposed to Dynamat, are there other alternative suppliers that make a product of similar performance at less cost? I really don't want to pay the brand name fees, if you know what I mean.
    Suggestions and sources welcomed. Thanks!
    Chris
  2. rayzorsharp
  3. scooper77515
    I used the same, or similar stuff. When you go to Lowe's, look for a roll of what looks like bubble wrap with aluminum foil on both sides. It was like 20 per roll, I used 2 in the car, 1 more behind the back seat and in the trunk.
  4. 71gold
    that is nothing like what i used...that is what i replaced...:yup:
  5. Dave B
    I sold one of my pinball machines, and used the money to buy Dynamat. :D
  6. JCWGrover
    JCWGrover Member
    Rochester MN
    1976 Maverick Stallion
    I used eDead on my mustang, was quite happy with it :)
  7. Rob 72
    Rob 72 Member
    Northern California
    1972 Grabber
    I used Dynomat
    I used dynomat in mine and yes it was exspensive. I drove it home and what a difference it made. Even with bad rubber seals the car was so much quieter. It sounded as if I had gotten into another car. I will check at work and see if there is a good alt.
  8. 71gold
    mine is so quite that now i have to chase down some...wind noise.:D
    (i think it's a vent window seal).
    ...:chirp:...
  9. curtisc
    curtisc Member
    Moscow...... Ks
    1978 F-150, 1971 Maverick, 79 Bronco
    FatMat has also been tried here, and is quit abit less than dynomat. i think ebay is the cheapest place to get it
  10. littleredtoy
    littleredtoy Seth
    North Carolina, Triangle Area
    '74 Comet GT
    I read an article in Muscle Car Review about insulating older cars.
    They used Dynamat, but I was surprised in the way that they
    used it.
    The article described the straight flat areas of your car as being
    similar to the skin on a drum. The longer the span, the more noise
    resonates from the drum. They used strips to cut down on the cost.
    They did not cover the entire floorpan, firewall, hood, roofline(under
    the headliner). They just used strips to cut down the noise waves.
    Looking at the pictures, I would say 50-60% of the bare metal was
    covered. They stressed to use it in the straight flat areas.
    On top of that, they used the aluminum backed fiber padding for more
    of a noise and insulation barrier.
    Seth
  11. Rob 72
    Rob 72 Member
    Northern California
    1972 Grabber
    Dynomat
    Mine is installed in squares and strips. There aren't any solid pieces anywhere on the floors, or in the doors. That alone will cut down in cost. Also Dynomat is heavy and dense. I wouldn't want to line the whole car with it, I would have to beef up the supension.
  12. lastchance
    lastchance Member
    Hingham , Massachusetts
    Has anyone tried Lizardskin?
  13. mean_maverick
    I also used the same stuff as 71gold and im impressed with it. i'll have some pictures up this weekend with the rest of my progress that ive been working on... quietly :D
  14. 71mavkidd
    71mavkidd Member
    Kansas City, Kansas
    what EXACTLY is that stuff you and 71gold used? I think i am going to go with that.
  15. mean_maverick
    go to Lowe's, visit the roofing section and it's called "Flashing" (normally used around chimnies, seams and such when roofing). it comes in a 6"x25' roll and has the aluminum backing. it's like $14.99 a roll. i bought 4 rolls, done my entire floor and doubled the layers over my firewall and trans hump and still have almost a whole roll left. well worth the money :thumbs2:
