Dyno Run!!!
Discussion in 'General Maverick/Comet' started by valleyracer, Oct 2, 2007.
  1. valleyracer
    valleyracer Member
    Ottawa Canada
    1977 Maverick Drag car 399 engine,C4 trans,9"with 4.33 gear ET 10.25 @ 128 mph
    Finally I can say the numbers are good!
    306 NA RWHP Dyno 345hp= 425hp at the crank! :)
    Richard
  2. Eddie Maverick
    Linda, Ca
    1974 Maverick LDO
    Nice numbers there
    What's all in it?
  3. valleyracer
    valleyracer Member
    Ottawa Canada
    Victor Jr intake Windsor Jr heads with KB light flat tops on H-beam rods, Compcams Extreme Energy flat tappet 294 and a 650 DP Holley! Compression at 9.5 and 36 degree's timing! PUMP GAS!
    Richard
  4. Thack
    Thack vision advicator
    Moreno Valley Ca
    Very nice
  5. Eddie Maverick
    Linda, Ca
    1974 Maverick LDO
    yes very nice indeed.
  6. maverick1970
    maverick1970 MCG State Rep
    Missouri
    Nice numbers
  7. valleyracer
    valleyracer Member
    Ottawa Canada
    Thanks
    Now it is going for a backhalf and Ladder bar suspension upgrade! Can't wait to TT in the spring...should be a blast down the track!
    Richard
  8. valleyracer
    valleyracer Member
    Ottawa Canada
    Do the air/fuel ratio seem a little rich? Jets are 72P 80S
  9. hotrodbob
    hotrodbob Member
    Central Coast, So.Cal
    Sold my 1971 Grabber
    Since you're in Canada is that Metric HP?:burnout::rolleyes:
  10. valleyracer
    valleyracer Member
    Ottawa Canada
    No but it should put the Mav into low-mid 11.00 territory on Pump gas!
    I have thought about a 100 shot or a roots style blower as an add on!
    9.5 to 1 is a little high for those isn't it?
    Richard
  11. scooper77515
    Is the picture in your avatar the car with this motor? I wouldn't expect tires to lift with those numbers. If so, I may not have to build that 393...:cheers:
  12. valleyracer
    valleyracer Member
    Ottawa Canada
    Same car with a mild 306...this engine is a lot more! Lot's of cam and converter!
  13. riporter
    riporter Member
    Charleston S.C.
    Richard I'd say your carb jetting is a good baseline to start with,,,do some plug reading at that first T-n-T and make adjustments from there.
    At that compression ratio you should be safe for a 100 shot. Depending on your rotating assembly (forged or not) particularly the pistons I wouldn't hit it with anymore than that.
    I think that 100 shot is gonna give you a lotta bang for the buck vs. the cost of a blower.
    Good Luck with it.
  14. valleyracer
    valleyracer Member
    Ottawa Canada
    Thanks,
    I will stay NA for now to get it track tuned and may make changes after that. The chassis is going for the backhalf next week and will have to be setup also! Can't wait till April...a long winter ahead:(
