e7 truck heads????
Discussion in 'Technical' started by justin has a 74, Feb 12, 2010.
  1. justin has a 74
    kentucky
    Would e7 truck heads have the same effect as mustang heads?
    Do they flow the same?:hmmm:
  2. Bryant
    they are the same heads. so they should have the same effect.
  3. baddad457
    Ditto................same heads for both.
  4. scooper77515
    E7te I think was on cars. Same on yours?
  5. Earl Branham
    Lugoff, SC
    I have the E7te heads on my car. Seem to work very well.
  6. baddad457
    E7TE's were used on all 87-97 Pickups and vans, plus the Mustang and Lincoln LSC 5.0. Not sure about the T-Bird/Cougar 5.0's, some did, some didn't get em. All the other car 5.0's got E6SE's.
  7. scooper77515
    Were those on a roller or flat-tappet engine? he needs to make sure his springs match the cam so he doesn't eat lifters like I did.
  8. TrikeKid
    TrikeKid Member
    Roy/Eatonville, WA
    '85 Toyota Pickup, 74 V8 Mav
    Roller engines in the mustangs, I forget when trucks got the roller block.
  9. baddad457
    If they've got flat tappet springs, then nothing, other than a reduced topend limit for valve float's going to happen.
  10. baddad457
    Trucks had roller blocks starting in 1986. But they didn't get the cam til 92.
