easy c4 install
Discussion in 'Technical' started by warboy, Nov 17, 2016.
  1. warboy
    warboy Member
    pennsylvania
    1972 ford maverick grabber, 1977 ford maverick 4dr 351 v8
    so in a few days im gonna be starting my 250i6-351v8. i am putting a better v8 c4 in my maverick and was wondering if there is any easy way to get the transmission installed. the engine shouldnt be that much of a challenge its just the trans im scratching my head about. also does anyone else run a mechanical fan with a 351?
  2. mavdog71
    mavdog71 Member
    Moreno Valley, CA
    '71 Maverick Grabber
    I install the engine and trans as a unit
    Static and 71gold like this.
  3. 71gold
    make sure you get the right converter and it's seated...:yup:
  4. warboy
    warboy Member
    pennsylvania
    the engine and trans are in my donor car as a unit and im putting new seals on everything
    71gold likes this.
  5. Hotrock
    Munroe Falls, Ohio
    When I had a 351W I used the fan, spacer and shroud from my stock 302. I can't believe I do not have a picture of this combination that I later changed to an electric fan. :(
  6. Krazy Comet
    The factory installed engine & trans as a unit... Imagine being on a moving assembly line and trying to get the engine & trans lined up while it's moving down the line... If both are out that's how I'd do it...
    When I install the 5.0 I left the fresh C4 with maybe 100 miles in place... Because of new converter issues(hub approx 1/4" too long) I had it back out three times... I got pretty good at it after the first time...
    71Mavrk likes this.
