Econoline springs
Discussion in 'Parts Interchange' started by facelessnumber, Nov 17, 2008.
  1. facelessnumber
    facelessnumber Drew Pittman
    Memphis, TN
    '71 Grabber
    Yep, they fit! I wrote a tech article about it.
    I figured we could keep that thread mostly clean, and use this one for discussing it in the true MMB style which usually ends up not belonging in a tech article...
  2. ratio411
    ratio411 Member
    Pensacola
    1972 Sprint and 1975 Maverick
    Posts that don't belong in a thread... we wouldn't do that. ;)
  3. facelessnumber
    Memphis, TN
    '71 Grabber
    I guess I was inviting derailment by even saying that... But what I meant was let's have the controversy of WHY we shouldn't put van springs on our cars over here, and the discussion of HOW to do it over there...
  4. rthomas771
    Might be best to use a C-clamp to hold things together before removing the pack of springs.
  5. ratio411
    ratio411 Member
    Pensacola
    I would like to point out that stout springs are surely a plus in the battle to keep our upper shock mounts secure. Weak rear springs invite excess pressure to be applied to those anchor points, which have shown to be lacking strength in our cars.
    Good job.
    I'm glad to hear of an easy option.
    Can I start hijacking now?
  6. tim keck
    sharps chapel,Tn
    So...did you keep the Mav main leaf and add 3 van leafs,or 4?
  7. facelessnumber
    Memphis, TN
    '71 Grabber
    Actually I only added two van springs, for a total of three per side. I used the larger two. I will probably keep experimenting, but for now I like this a lot. My only complaint is I'm about an inch higher in the back than in the front. I could correct that with a different spring configuration, I could use 1" lowering blocks, or I could leave it alone. Haven't decided which way to go yet, and I probably won't until I settle on my final spring arrangement.
  8. ratio411
    ratio411 Member
    Pensacola
    You are doing a good job as guinea pig on this subject!:D
    Keep posting your findings. This is interesting.
  9. Jamie Miles
    Hows about taking and posting pictures of the car with each configuration as you experiment to give others an idea which leafs are best to start with to get the look they want? Say a profile shot from the front, a shot looking directly at the side and a shot from the rear.
  10. facelessnumber
    Memphis, TN
    '71 Grabber
    Alright, will do. I can't promise to do it quickly, but as I change 'em up I will take pics. (y)
  11. facelessnumber
    Memphis, TN
    '71 Grabber
    Update:
    I wouldn't have expected used springs to "settle" like new ones, but they did. It sits just about perfect now. A bit less than an inch higher than the front when the trunk is empty, and pretty much level with a spare tire, a full tank of gas and some tools in it.
  12. Bob Wiken
    Fayetteville, Arkansas
    Great info. I have 4 leafs in mine that the local spring shop diod before I bought my car. The front still sits too high. I'm not changing rears til i cut the fronts a bit. This absolutely great info though
    thanks
  13. facelessnumber
    Memphis, TN
    '71 Grabber
    Yeah, now I really want to play with the front springs too, but I'm hesitant with the 235's in the front. I'm afraid if I do anything to the front it might rub when I steer. It doesn't now, but it's got to be on the ragged edge...
  14. CaptainComet
    First ... truck springs ...
    Next ... truck shocks! ... see my tech article here ...
    http://mmb.maverick.to/showthread.php?p=507155#post507155
    Faceless, I am very interested to see a picture of the ride height that your car is at now. I saw some of the pics in your gallery and agree that it needed help. Mine does too. I am planning on experimenting with this myself. Might even make half-leafs for traction purposes.
  15. facelessnumber
    Memphis, TN
    '71 Grabber
    Very, very cool!
    I don't have any good pics yet, but here's what I do have.
    This is with 1/4 tank of gas, an empty trunk, on the day after I installed the springs. After some driving and adding my spare tire, lug wrench and jack it came down quite a bit. I will try to get you another pic today on my lunch break.
