Electric Fan or Shroud?
Discussion in 'Technical' started by Northern, Mar 6, 2015.
  1. Northern
    Northern Member
    '74 Maverick
    Thats the question... should I get a shroud for my current fan, or install an electric fan?
    If I go the electric fan route, there are several out there under $100... are they reliable enough?
    Thanks for your inputs guys,
    Northern
  2. rthomas771
    If you have a V8 then go with a mid 90's Taurus 2-speed fan
  3. Hotrock
    Munroe Falls, Ohio
    It all comes down to what you are trying to accomplish. If you do not have any cooling issues and want to keep a stock appearance go with the stock shroud. If you have cooling issues or if you want to gain a couple of horsepower, go with the electric fan. There was a recent discussion on this site about electric fans at the following post:
    http://mmb.maverick.to/threads/electric-fan.102794/
  4. scooper77515
    Going to be WAY easier to find a fan than it will be to find a shroud.
    baddad457 and doncomfort like this.
  5. mercgt73
    I would recommend an electric fan ONLY if you have done a charging system upgrade.
    Static likes this.
  6. Static
    Static Member
    Apache Junction AZ
    1975 Maverick 2 Door
    x2 I would not want to run an efan on a stock alternator. I upgraded to the 3G from a junkyard for like 40$
  7. Hottrod1991
    Hottrod1991 Member
    PGH,PA
    73 maverick
    All of tbe above
    ulgrade to an internally regulated 4 wire alt with about 130 rating.
    A good SPAL Fan (s) or used 2 speed taurus sho e-fan
    A shroud
  8. bmcdaniel
    Got my Taurus fan off of Craigslist for $30, got a rebuilt 150 amp 3G alternator off ePay for $100. Cheap upgrade.
    Northern likes this.
  9. fuelish351
    fuelish351 Member
    San Jose, CA
    73 Maverick Grabber 2.3 Turbo
    I got a taurus fan from pick and pull, stock 40amp alternator worked great for probably the past 6 years. dont really need the high speed though. Had a 400hp 302 with a 6 cyl nova radiator and as soon as I turned the fan on the temperature would start dropping. Hardest part will be mounting even still not too dificult.
    rotorr22 likes this.
  10. baddad457
    I mounted an unknown E-fan pulled outta the trunk of a 64 T-bird on the aluminum radiator in my Comet with a shroud fab'd by "you know who" several years ago. It's been dead nuts reliable ever since (knock on wood, specially after my coolant problems in another thread LOL)
  11. rotorr22
    rotorr22 Member
    Columbiana, Ohio
    If you have a fuelie engine, I can understand running a higher output alternator with an electric fan however, I am not convinced it is necessary on a carb motor provided you have an adequate battery capacity.
