Electric Fan?
Discussion in 'New Members Forum' started by NaughtyDog, Jan 28, 2015.
  1. NaughtyDog
    NaughtyDog Member
    New Castle, DE
    1969 1/2 Maverick
    Hello everyone I have a 73 Ford Maverick and as of right now I have the standard fan. I am trying to switch to and electric fan right now, but the only problem Im having is deciding on what kind of electric fan is best suited for the maverick, and from experience what has worked well in the past for you?
    Iv'e heard a ford taurus fan would fit, though (I've read it but nobody has described what year) work well, but can you guys please help me.
    If anyone has made the switch what fan did you use. Also if I was not to go the route of buying one from the junkyard, what newer style electric fan would work?
  2. Rasit
    Rasit Member
    SE Pennsylvania
  3. Hottrod1991
    Hottrod1991 Member
    PGH,PA
    73 maverick
    if you go new after market
    SPAL fans are the way to go
  4. Hotrock
    Munroe Falls, Ohio
  5. NaughtyDog
    NaughtyDog Member
    New Castle, DE
    1969 1/2 Maverick
  6. Krazy Comet
    I have a 16" fan and shroud from a supplier in GA(I think), got it from ebay a little over a year ago, $91 shipped... They were pricing them at $159 but listed one for bids at $89 and only had two bidders(I sniped at 10 sec to go)...
    Paul Masson likes this.
  7. Hotrock
    Munroe Falls, Ohio
    Damn nice fan!!!!!! Great price. Probably can't duplicate that deal!!!!!!
  8. NaughtyDog
    NaughtyDog Member
    New Castle, DE
    1969 1/2 Maverick
    Is this still for sale, If not that sucks that I just seen this!!!!!!
  9. Krazy Comet
    Yeah looks like they are still available but best price I saw on ebay for fan & shroud is $159(at least reg price hasn't increased)... Less the drilled holes, what you see is what you get, I used a different plug on mine as I couldn't match the one on the motor...
    http://www.ebay.com/itm/NEW-ALL-ALU...ts=Model:Maverick&hash=item418d6e73d3&vxp=mtr
  10. Hottrod1991
    Hottrod1991 Member
    PGH,PA
    73 maverick
  11. Hottrod1991
    Hottrod1991 Member
    PGH,PA
    73 maverick
    Whoops
    actually the one ive linked is a pusher
    youd be better off with a puller fan which they have
    pretty sure most of their fans Work as both
  12. NaughtyDog
    NaughtyDog Member
    New Castle, DE
    1969 1/2 Maverick
    I was looking up puller and pushers, which one would give you the most airflow if at all, and would be best suited?
  13. mav1970
    I have used Spal electric fans in stock cars that peaked at 6500 RPM's at the end of the straight away with no problems so I bought one for my Maverick along with an AFCO aluminum cross flow radiator
  14. Hottrod1991
    Hottrod1991 Member
    PGH,PA
    73 maverick
    Puller will draw more cfm
    pusher fans tend to obstruct air flow a bit since its in front of rad versus behind
    lastly get a fan shroud to Make the most out of the fan
  15. Hotrock
    Munroe Falls, Ohio
    That price is just the fan and does not include a shroud. If that 16" fan does not mount directly against the radiator fins you will have a gap and air will take the path of least resistance, that being through the gap and not the radiator. You do not want that. In other words, you need to take precise measurements to ensure a good fit.
