Electric Radiator Fan
Discussion in 'Technical' started by HarleyGA, Oct 10, 2017.
  1. HarleyGA
    HarleyGA Member
    Acworth, GA
    73 Grabber,
    It looks very straight forward but doesn't hurt to ask for advise. My car has air conditioning so I will need to factor that into the wiring. I am considering using "Allstar Performance Curved Blade Electric Fans ALL30076". Only $95 at Summit Racing and wiring it up with "Derale Single-Stage Fan Controllers 16735". What is everyone else using?
  2. 71gold
    I just mounted a Volvo fan with Volvo relay today...A/C car.
  3. 71Mavrk
    71Mavrk Member
    Nevada
    Taurus junkyard fan and Dakota Digital controller. On an AC car and that thing can move some CFM.
    Micah
    jasonwthompson and 71gold like this.
  4. rthomas771
    I think that 1980 cfm is too small for a 6-cyl. Look for something around 2800 cfm or better to cool a V8
  5. jackieblue47
    jackieblue47 Member
    mich
    1973 grabber maverick 1977 grabber 1966 mustang coupe 1989 ranger drag truck 2012 f-150 fx2 twin turbo
    new Taurus fan from rock auto $85 cools my 400 hp small block no problem stays at 165 on 90 degree days this is a 2 speed fan as original
    jasonwthompson likes this.
  6. 71gold
    I once had a Taurus fan with a Volvo relay controller...:thumbs2:
  7. 71Mavrk
    71Mavrk Member
    Nevada
    Jackie,
    Was that just for the fan motor or the whole assembly?
    Micah
  8. mojo
  9. mojo
    I agree w/ Jeff, a 1600 is not nearly enough, esp., in the southern part of the country. I don't think it wud cool the car even if AC is not used. I'm running Derale single fan controller & Flex-a Lite 118 Low Boy @ 2500 advertised cfm; on days around 90+ degs. This is w/ a DIY constructed fan shroud, it will run 220+ waiting for train/parades, etc, 20+ min wait.
  10. jackieblue47
    jackieblue47 Member
    mich
    the whole thing had 3 difference makes to choose from
  11. 71gold
    I ordered my new Taurus fan through LKQ. got the Volvo relay at Advance Auto parts.
  12. stumanchu
    stumanchu Stuart
    Portland, OR
    I have junkyard Taurus fan, junkyard Volvo controller, and BMW temp switch (the 177 degree low speed) 3 core factory radiator, 13lb cap. I am going to install some LEDs, 1 for each speed, so I can tell what it is doing. It will idle forever with the low speed on more than off, but does turn off.....have not tested in severe heat, and dont have AC.
  13. 71gold
    I was going to do the lights once but it was only going to tell me there was power going to the fan not that the fan was running.
  14. Hotrock
    Munroe Falls, Ohio
    What do these fans look like installed? As thick as they are I would think there would be issues with the fan hitting the water pump shaft. Can anyone post some pictures?
  15. mojo
    I had to offset fan to pass side of pump pulley and made shroud for driver side.
