Electric water pump & Fan?
Discussion in 'Technical' started by Zip4747, Dec 2, 2016.
  1. Zip4747
    Zip4747 Member
    Philly PA
    1971 Ford Maverick
    Ok looking for pros and cons. Thinking about switching to an electric water pump & electric fan, any help would be very much appreciated. So Thank you in advance
  2. rthomas771
    Have no problem with the CRS electric pump
  3. COMETIZED
    COMETIZED Member
    Florida
    70 Mav. 74 Comet
    We use a Lincoln Mark 8 Puller Fan & "modified" shroud also a smaller SPAL electric fan in Front for the AC on Four of our Cars. Really does a good job. Don't know enough about electric pumps but I'd make sure you select one for the ' STREET ' ! Some are designed for the STRIP . ( I would ask someone who KNOWS about the pumps before buying one.) When you select your fans , make sure you have enough ROOM for both to function properly if you run Dual Fans . I hope everything runs cool .
    Cometized
    (Chip)
  4. 71gold
    I had an e-waterpump and e-fan on my 347...Loved it.
    when I first installed it there was too much shine from the backing plate. I cut off all the plate I didn't need and wound up with...two spacers.
    If you sit still long enough, it will cool down into the 170s.
