Electrical issue
Discussion in 'Technical' started by Tcat, May 11, 2017.
  1. Tcat
    Tcat Member
    Mayfield, ky
    1970 Ford Maverick
    I have a 1970 Grabber with a voltage surge issue. When the light are on, give it gas they are bright, let it idle they go dim. I've changed the alternator and voltage regulator, even swapped to an internally regulated alternator and still have the same issue. The radio will even go off and come back on when I clutch to change gears. Don't know what else to look at. Any ideas?
  2. 71gold
    :Welcome:...:Handshake:
    what RPM is your idle set at?
  3. Tcat
    Tcat Member
    Mayfield, ky
    1970 Ford Maverick
    1000 rpm.
  4. Maverick Dude
    Maverick Dude Member
    Cranbrook, BC Canada
    Clean your main ground wire connections. Also clean the battery posts and if no difference try another battery that you know is good.
    :scratchchin:
    MD
  5. 71gold
    what engine do you have that requires...1000 RPMs at idle?
    have you checked the alt. to see if it's charging at full voltage?
  6. Krazy Comet
    Do you have underdrive pulleys?? At 1000 RPM alternator should supply enough current to operate all accessories...
    If battery voltage is less than 12v with engine off & headlights on, you likely have a failing battery...
  7. BigDog41364
    BigDog41364 Member
    Kalamazoo Michigan
    1975 maverick
    Also check the ground wires at the head lights. I had one head light that was doing the same thing, that was the fix
  8. mavdog71
    mavdog71 Member
    Moreno Valley, CA
    '71 Maverick Grabber
    Grounds, Grounds, Grounds ... If that don't fix it put headlight on relays
  9. Tcat
    Tcat Member
    Mayfield, ky
    1970 Ford Maverick
    Thanks guys, I've started tracking all my grounds down and hopefully I'll find my issue. I'll let you all know when i find it.
