Electrical/Wiring Problem
Discussion in 'Technical' started by BossMaverick87, Nov 11, 2009.
  1. BossMaverick87
    BossMaverick87 Member
    California
    Maverick with cougar taillights
    While in the middle of a auto-to-stick conversion, my car lost the ability to use the headlights and the brake lights. I noticed that there is a pink and black wire hanging next to my column, so I assume I disconnected something upon installing the clutch pedal bracket. And from a wiring diagram, it says that it's suppose to be connected to the neutral safety switch. My questions are:
    1) Would said mentioned pink-black wire cause the problem?
    2) Where do I reconnect the wire back to my neutral safety switch
    (pictures would be very helpful)
    Thanks in advance
  2. maverick1970
    maverick1970 MCG State Rep
    Missouri
    You didn't specify a year. You can go to www.maverickcomet.com look under features\wiring diagrams you should be able to trace it down.
  3. BossMaverick87
    California
    it's a 1972 Comet, and I've never been very good at reading these old diagrams as they're very... compact, nor have I ever been good with wires in the 21 years that I've been alive. I was hoping someone would have a picture that I could refer mine to
  4. Demmitt
    Demmitt nutz and boltz
    Sandsprings, Oklahoma,
    1976 2 door, 1969.5 2 DOOR
    lighting issues
    ok hear we go i pull the switch. the lights come on but no brake lite. turn off headlight. brake lights work. no blinkers ever. this is killin me.:cry:
  5. diddie
    diddie Member
    indiana
    two 1977 Maverick 2drs.
    you've got a ground problem some where! check as many as you can find and you will find one loose or detached!:tiphat:
  6. PaulS
    I think you may have the brake light hooked up to the tail light circuit. When you hit the brakes the tail light is coming on but when your tail lights are on the lamp is too bright to show the brake light is on. Swap the wires to see if it changes or remove the bulbs and put them back in correctly.
  7. simple man
    simple man Member
    Bunnell,Florida
    Check and see if you may have pulled the harness plug partway loose. It's to the left and above the pedal assembly.:)
