engine/casting codes...
Discussion in 'General Maverick/Comet' started by 289, Nov 4, 2012.
  1. 289
    289 Member
    Prescott Wisconsin
    73 grabber
    ok i took out my motor yesterday and here is my code for it-
    D4DE-6150-AA
    for my translation skills it says it was made in 1974 in a ford falcon...can somebody help me out here? also they guy SAID it was out of a 1966 ford mustang...this might not even be a 289 because the production was stopped in 1968 if i am correct. could the D also stand for a maverick maybe??
    and my transmission,
    C6AP-7D027-C
    and now this gets interesting because this was made in 1966... if i am correct. my hypothesis is that they guy i bought it from was confused and ment to say the tranny was from a 66 mustang and the engine is actually the original 302???
  2. Joe Dirt
    Definately not a 289
  3. 289
    289 Member
    Prescott Wisconsin
    73 grabber
    what differences do the 289 and 302 have that i can look for?
  4. Krazy Comet
    Yes "D" was also used for Maverick(Falcon prod ended in '70 so it'd be impossible to be from a Falcon)... With that casting it's no doubt a 302, last 289s were built in C8xxxx blocks... Still engine components often have a different carlines(most often fullsize) as part of the number...
    http://mustangtek.com/FordDecode.html
  5. groberts101
    groberts101 Member
    Minneapolis, MN
    what are the numbers off the heads?
    Hey.. maybe you got lucky and have high compression heads off the 289 too? :huh:
