engine/frame mounts
Discussion in 'General Maverick/Comet' started by steel, Feb 7, 2009.
  1. steel
    steel Member
    NC
    1974 Maverick 2-Door
    i have a i6 car....can i use the frame mounts in the car with the autokrafters engine mount (92220&92221) for v8 engine?​
  2. ratio411
    ratio411 Member
    Pensacola
    1972 Sprint and 1975 Maverick
    You have to get v8 frame mounts and v8 engine mounts to go on top of those.
    The engine mounts are available at your local parts store for not much money... 10-15 bux each.
    The frame mounts are available from AK, but are very expensive... 100 bux or more for a set. If you have some patience, they show up on the site here for less than half that pretty regularly. There are some early frame stands from other Fords that will work too. HOWEVER, the engine mounts are unique to Mavericks and do not interchange.
  3. dweesel
    dweesel Member
    Lindsay Ont. Canada
    I am in the same boat with you but I ran out of patience waiting to find a cheaper set. I bit the bullet and bought the frame and engine mounts for $153 US. They are from Auto Krafters from their E-bay store. Plus the $40 buck shipping. If you can wait it out more power to ya.
  4. maverick1970
    maverick1970 MCG State Rep
    Missouri
  5. ratio411
    ratio411 Member
    Pensacola
    Good info!:Handshake
    I knew there was someone with them for right at 100 bux.
    A penny more is just robbery!:rolleyes:
    The last 3 or 4 pair that have come up on the forum here have been 40-50 bux. But you have to have patience to save that 50 bux.
