engine id ?
Discussion in 'Technical' started by classic ccg, Jun 16, 2012.
  1. classic ccg
    ringgold GA
    72 maverick
    ok so i have been trying to decode the dang things but no luck all i know is thay are 80s
    so the engine i pulled today is #E0af d30 20
    and thin for the engine that's going in to the maverick # 24 e6se ba
    plz help:bowdown:
  2. baddad457
    Not sure what you want to know here, your post is full of misprinted info. That E0af I suspect should read E0AE, which is a lightweight 302 block (the lightest as a matter of fact of all 302 blocks) And in my opinion should be left for the scrap yard. E6SE can be found on both the early 302 roller block and heads used on the Crown Vic/Towncar/Marquis 5.0.
