Engine Mounts
Discussion in 'Drag Racing' started by scooley, Oct 26, 2007.
  1. scooley
    scooley New Member
    Texas
    Im going to cram a 302 H.O. in my Maverick. Where can I get some custom engine mounts?
    :idea::idea::idea::idea::idea::idea::idea::idea::idea:
  2. Rick Book
    Rick Book Member
    Thailand
    Missing my old '70 Maverick
    You won't need any "custom" mounts. The OEM V8 engine mounts will work.
  3. scooley
    scooley New Member
    Texas
    How do I get to your online shop? How much are they? Will I have to modify the shock towers to get the 302 to fit?
  4. maverick1970
    maverick1970 MCG State Rep
    Missouri
    The 302 was an option in the Maverick from 71-77 so you won't need to modify the shock towers.
    Plenty of info on the swap here in the forum
    http://mmb.maverick.to/showthread.php?t=36034
    http://mmb.maverick.to/showthread.php?t=36038
    http://mmb.maverick.to/showthread.php?t=4581
    The frame mounts are available from
    Auto Krafters www.autokrafters.com
    The Maverick Connection http://stores.ebay.com/Maverick-Connection_W0QQcolZ4QQdirZ1QQfsubZ0QQftidZ2QQtZkm
    Crites Restoration www.critesrestoration.com
  5. don graham
    if you have a 6 in there now you need to get v-8 frame mounts. the engine mounts can be bought at any parts store like napa, autozone or whatever you got nearby. the frame mounts are expensive and can be found from some members on here or ebay. you should also add the v-8 belly bar and most add the dual exhaust tranny crossmember.:)
