Engine Question
Discussion in 'Other Automotive Tech & Talk' started by scrapper60, Nov 16, 2015.
  1. scrapper60
    scrapper60 MCCI Member
    Alabama
    I have a 300ci 6 cyl from a 65 truck in my newest project 1960 f100. I want to put a c4 auto in it. Can't find a flexplate with a ring gear. Would the ring gear from the stick fly wheel fit the auto flexplate?
  2. Krazy Comet
    Nope never in any case...
    Assuming you are looking for a 157 tooth flexplate, it's possible to cut the weight from a 302 flexplate to make it zero balance... What I don't know for sure is if the crank bolt pattern is same...
  3. scrapper60
    Alabama
    hmm, I think autozone sells a flexplate for 300 6 without the weight. I was wondering why.
  4. Krazy Comet
    What's the C4 from?? If it's a case fill for passenger car it should use the 157T I mentioned... The ones for trucks use a 164T, that is slightly larger...
    The 250 used a zero balance 157T flexplate...
  5. scrapper60
    Alabama
    It's from a Maverick. Yep case fill.
  6. Country Mav
    Evans, Louisiana
    72 2-door Maverick 308/C-4
    Did you get it going?
