engine running!
Discussion in 'General Maverick/Comet' started by Kmurray337, Jul 12, 2009.
  1. Kmurray337
    Kmurray337 Member
    NH
    Comet
    FINALLY!! After all the hard work shes finally running. 302 engine swap sucssesfull!
    only problem is that she heated up way to hot and fast. i beleive its becasue of these two hoses but i cannot figure out why. we tried pinching it off but still heated up to fast.
    any sugestions? Thanks! :drive:
  2. madman21
    madman21 Beer is good
    Albuquerque, NM
    1976 2dr Mav 410ci
    Good job man!!!
    :bouncy:
    That port is for your heater hose. Hook it up and it should run cooler. The other hose goes from the heater core to your manifold.
  3. Kmurray337
    Kmurray337 Member
    NH
    Comet
    where does the top water pump hose go to?
    I dont have any other ports in the intake though?
  4. madman21
    Albuquerque, NM
    1976 2dr Mav 410ci
    The top one goes where you have it...to the tstat housing.
    You have a port into the waterjacked on the manifold. Maybe you plugged it with a vacuum switch or something. Mine has three ports.
  5. madman21
    Albuquerque, NM
    1976 2dr Mav 410ci
    It sounds sweet BTW..
  6. Kmurray337
    Kmurray337 Member
    NH
    Comet
    ohh ya. I have two behind carb and one up twords the front. which does it go to? what kind of connecter do i have to go get? Thanks a bunch! ive been tryin to look at pics to get it but i cant see any clear enough so i just bi-passed it.
  7. madman21
    Albuquerque, NM
    1976 2dr Mav 410ci
    I just bought a 3/8s threaded 3 inch pipe at home depot and hooked up to one behind the carb.
  8. Kmurray337
    Kmurray337 Member
    NH
    Comet
    alright awesome, thank you
  9. albrntt
    albrntt Member
    hoses?
    The small bypass hose it correct. One heater hose runs from the water pump where you have it plugged, to the heater core. The other heater hose goes from the port you have your temp gauge plugged into to the heater core.
    If you see it heating up really quickly and can't find any reason you might have a head gasket backwards. The gaskets are the same for both sides, but you have to make sure the water port holes got to the back of the block on both sides. I found this out the hard way a long time ago. It was a lesson I'll never forget. Just a thought, I hope that's not the problem.
    Lee
  10. fastback86
    fastback86 Loose cars and fast women
    FL
    1974 Maverick 351W, 1985 5.0 Mustang coupe, 1996 F150, 2004 Subaru WRX Sti (Don't shoot me, it goes like hell!)
    Also may not have all the air burped out of the cooling system. I didn't see a fan on it either.
  11. albrntt
    albrntt Member
    Running it without the heater connected shouldn't make it run hot. Check the lower radiator hose and make sure it's not collapsing. That will keep you from having circulation if it is.
  12. Kmurray337
    Kmurray337 Member
    NH
    Comet
    When i had the engine bored out he warned me about that and i made sure i looked for the 'front' label on the gasket :dancing:
    All hoses are running fine, we double checked everything while it was running. and i have a 12'' 1200cfm fan hooked up to radiator, its just hugging right against it.
    We are in high hopes that it is just the heater core hoses, im going to be heading out to fix this right after coffee, ill keep you guys posted. thank you for the info :Woot:
  13. 71gold
    for me...water not circulating...is the only way the engine will heat up quick...:yup:
    i always leave the t-stat out untill i get the engine ran in.
    this makes it less possible for an air lock and/or a t-stat sticking closed.
    the heater hose can be a short piece looped from the...intake port to the waterpump...the heater hose will play no part in the...hot/cold condition of the engine. it has a...heater control valve... that is closed w/heater off.
    is the waterpump, the right rotation?
    ...Frank...good luck...:Handshake
  14. 71gold
    what condition is your rad/heater core? i have seen new engines stop up an old rad/heater core from the max flow of a clean engine.
    at the shop i hang out at, they replace the rad. and back flush the heater core of every new engine install.
    ...:yup:...
  15. albrntt
    albrntt Member
    Do you have the correct water pump? Some of those spin backwards, I'm not sure how to tell you to check it, but someone else might be able to help you. All I know is that there are some 289/302/5.0 water pumps that rotate opposite. Good luck.
