Engine Swap
Discussion in 'Parts Interchange' started by Maverick_43, Jan 25, 2005.
  1. Maverick_43
    Maverick_43 Member
    louisiana
    1972-maverick-grabber
    I am going to put a 90 mustang roller motor in my 72 grabber, Do you have to change the oil pan,and the timing cover for the oil dip stick.For the motor to fit.
  2. maverick1970
    maverick1970 MCG State Rep
    Missouri
    If the Maverick has the stock suspension you will need to change to a front sump oil pan and move the dipstick to the front timing cover so you can get correct dipstick readings. You will need to plug the hole for the block mounted dipstick. Some timing covers have the boss so it can be drilled for the dipstick others don't.
    Keep in mind that the 90 engine has a reverse rotation water pump so if you intend to keep it that way you will need the correct timing cover. You can buy new aftermarket covers on e-bay or most of the Ford engine builders like Bennett Racing, Keith Kraft, DSS, Ford Perfomance Solutions, Coast High Performance etc...
  3. Kilg0re
    Kilg0re Doh!
    Lees Summit, Missouri
    mmmm Someone never put my oil dip stick to the front of my motor... Its out of a 84 mustang. You say I can buy a timming cover that will already have the hole in it? I already plugged the old one and everything...
  4. Kilg0re
    Kilg0re Doh!
    so i will have to drill a hole in my block right?
  5. maverick1970
    Missouri
    If you have a front sump oil pan you should have a timing cover mounted dipstick. If you have a rear sump oil pan you should have a side block mounted dip stick.
  6. Maverick_43
    Maverick_43 Member
    louisiana
    I have the motor in my 1984 F150 wright now. I want to go race it one more time in April,1,2,&,3 of 2005 at fun ford weekend, at noproblem race way in BellRose Louisiana. Then i want to put it in my maverick, And have a lot more fun.Then i will have to buy a posi unit with some 3.55 or 3.73 gear for an 8". Thanks for the info guys.
