Engine WTF
Discussion in 'Technical' started by JAYSMAV, Sep 5, 2016.
  1. JAYSMAV
    JAYSMAV Member
    Ohio
    '73 Comet 302 LDO auto, '70 Maverick I6
    So I have a friend… picture 2001 302 block, '90's E303 roller cam, GT 40 iron heads, 1:6 roller rockers, 67 Lbs valve springs (157Lbs open pressure), hydraulic roller lifters and stock '01 push rods. cam is advanced 4 degrees... ALL THE PUSHRODS ARE BENT!
  2. MaverickDan
    Midlothian, VA.
    73 Maverick 4dr
    Did he check piston to valve clearance?
  3. JAYSMAV
    JAYSMAV Member
    Ohio
    i dont think so. he was told everything would work.
  4. ADOR
    ADOR Member
    Northeast Louisiana
    1972 Comet Gt
    Did he use non roller push rods? They are shorter on Roller cam engine because the roller lifter is longer, 6.272 for Roller and 6.87 for the non roller push rod length.
    What pistons is he using? Do they have valve reliefs?
  5. JAYSMAV
    JAYSMAV Member
    Ohio
    I think he said "stock" on the push rods. Its possible the longer ones were used. He did say "its a full roller now". I dont know what pistons are in the block. i cant figure out how to post pictures from my i phone on here. If i did, id post a pic of the push rods. never seen anyone bend a rod (s) like this.
  6. rotorr22
    rotorr22 Member
    Columbiana, Ohio
    He should not have had an issue with those small valve GT40 heads with an E303 in a roller engine with 1.6's, even with a 4 degree advance. I run the same cam with AFR 165's and 1.7's with an abundance of PV clearance.
  7. JAYSMAV
    JAYSMAV Member
    Ohio
    Exa
    exactly what we thought also. That's why the guy picked this set up, it's all been done before. It's a "safe" build, nothing ground breaking about it. My guess is the cam was off by a lot. There was a question as to how the timing marks should have been lined up. Maybe that was it?
  8. groberts101
    groberts101 Member
    Minneapolis, MN
    Nailed it. I highly doubt you could find any point of PTV interference no matter where you degreed that small'ish cam in. Not like they come from the factory with a 0 deck height either. And even if the degree point was the prime cause of such an issue.. you'd never bend all 16 pushrods. This type of boo-boo is the main reason we do mockups to check everything in the first place.
  9. JAYSMAV
    JAYSMAV Member
    Ohio
    Only the intake valves were bent.
      File size:
      92.6 KB
      19
