Exhaust Systems for Mavs?
Discussion in 'Technical' started by tbirdz12, Jun 25, 2006.
  1. tbirdz12
    tbirdz12 Member
    Sun Lakes, Az
    69.5 Mav
    Are there any 2.5" mandrel bent exhaust systems available that will work on a 4 door mav? Maybe a mustang system or something. Looking for a header back piping setup.
    My local muffler shop only does the pinch bent systems. :bs:
    Thanks
    tim
  2. bmcdaniel
    bmcdaniel Senile Member
    Years ago I put an early Mustang kit on my Mav, the only part that didn't fit quite right was the tailpipes. They stuck out at a different angle, don't remember if they were up or down too much. Just cut and welded that last angle.
  3. scooper77515
    Fan2488 just recently put one in his 73 two-door, I think. If I remember right, he bought a mustang kit (not sure which year) and maybe had to make minor mods or cuts to make it fit.
  4. fan2488
    fan2488 Member
    spring,TX
    1969.5 maverick, 1972 grabber
    i do have a mustang exhaust.2 1/2" mandrel bent have not installed it yet.its for a 1966 -1973.got it from jegs 149.95 with turbo mufflers. the next saturday i dont have to work i will install it(i hope).i will let you know how it worked.
  5. tbirdz12
    tbirdz12 Member
    Sun Lakes, Az
    69.5 Mav
    (y)
  6. tbirdz12
    tbirdz12 Member
    Sun Lakes, Az
    69.5 Mav
    Any updates?
    Thanks
    tim
  7. maverick5.0
    maverick5.0 Member
    Caribbean/Puerto rico
    1976 maverick,347 stroker,c-4,sm bumpers,frt air dam/73 maverick,5.0 grabbber hood,four on the floor,v8,rear spoiler,...
    had my exhaust done at a local muffler shop and the sound is loud with original (old school ) flowmasters, single chamber, 2.5 with cross-overs !! if you have a mild engine
    don't sweat the mandrel bending, just go with 2.5 pipes and your good to go!! the cross-
    over gives you about 3 to 5 HP and 8 to 10 in torq, it also cancells out some noise too !! paid only 60.00 dollars for labor/2.5 tubing,120.00 USD flowmasters.
    the drivers side at the rear of the car is a real tight fit because of thr way the gas tank sits. nothing beats a custom exhaust install !!
  8. ford84stepside
    ford84stepside Lone Wolf
    Berry Alabama
    1947 Lincoln Zephyr Coupe
    I've often wondered about using a Mustang exhaust kit myself, how well does it fit around the gas tank? And where does it dump out? The rear or out the sides behind the tires?
  9. fan2488
    fan2488 Member
    spring,TX
    not yet.i have had to work on the weekend thelast 4 weeks. it does look like i will have to have one pipe bent a little more.
  10. Mavaholic
    I can tell you that I"m pretty sure the Mustang tail pipes will not work on 71-77. At least not the left side. The tank is more centered on the mustang. Of course, if you convert to a mustang tank, you just might have a better chance.
  11. fan2488
    fan2488 Member
    spring,TX
    mine is converted to the mustang tank
  12. spork1o1
    spork1o1 Member
    Michigan
    gas tank
    what is the diferances in the mustang and maverick/comet tanks?
  13. 1972Grabber
    1972Grabber Always Broke
    SAN ANTONIO, TEXAS
    1972 Maverick Grabber
    Talk about VAGUE. Do you, or can you get the info from him? Please.
    And the number of that kit from Jegs would be what? Any info is greatly appreciated. I am tired of running the rusty piping that was given to me from another car to hook up and kept me from running open headers. The car sounded awesome through the headers. Neighbors didn't like it much but who cares?
  14. ford84stepside
    Berry Alabama
    Thats what I thought, especialy the left one and exiting out the rear. I thought maybe if it exited behind the wheel to the side, over the spring it might have a chance....
  15. fan2488
    fan2488 Member
    spring,TX
    And the number of that kit from Jegs would be what? Any info is greatly appreciated. I am tired of running the rusty piping that was given to me from another car to hook up and kept me from running open headers. The car sounded awesome through the headers. Neighbors didn't like it much but who cares?[/QUOTE]
    the part number i got is #555-30553.this part number is for header back exhaust. i do not know how well these fit. i have not installed them yet.it does look like some pipes will need to be bent more. not sure wich one or how much yet.
