Exhaust
Discussion in 'Technical' started by Sherrod, May 29, 2012.
  1. Sherrod
    Sherrod Member
    73 mav 250
    What would you guys recommend for a stock 250. It has some headers on it though. Still has the 1bbl carb on it. Everything else is stock. We want to dump the exhaust before the rear axle if that if helps....Just wanna know what the best size diameter pipe to use.
    Thanks
    :yahoo:
  2. maverick75
    V8 swap :D
    Stick to 2-2.5", I would dump it after the rear end.
  3. Gene Fiore
    Gene Fiore Member
    Goodyear, AZ
    I wouldn't go over 2inch on stock 250. (y)
  4. 71gold
    I would like to see a pic...:Handshake
  5. rthomas771
    1-3/4" if going with dual exhaust, 2-1/4" if single exhaust...dump it after the axle
  6. groberts101
    groberts101 Member
    Minneapolis, MN
    2 1/4 using mandrel bent tubing.
    2.5 if using compression bends
    then rejet the carb and dial in the timing(not necessarily in that order) after you add an aftermarket muffler and free flowing air cleaner.
