explorer heads aka gt40s
Discussion in 'Technical' started by justin has a 74, Oct 1, 2009.
  1. justin has a 74
    kentucky
    whats a good price to pay for explorer heads at a junkyard????
    hoping that selling my old camera will get me some big bucks:D
  2. cenc1984
    cenc1984 killa 72
    Middleburge FL.
    1972 Maverick Grabber
    :huh:got mine for 50 bucks. just told em I got some cast iron heads off a 302.I didnt tell em anything specific. and dont forget the pushrods. they are a different length.:huh: pops
  3. justin has a 74
    kentucky
    thanks for the push rod advice and the price(y)
    i thought it would be more than that:)
    should i mention that their off an explorer if they ask;)
  4. 302-72-mav
    302-72-mav Member
    sactown CA
    the pick n pull prices went up look at the price chart's they have hanging up do they charge more if they are off a truck than less if they are off a car ??
    are these heads aluminum or cast iron i know they sell between 300 to 500 on craig's list
  5. scooper77515
    Most of us pay around $300 from someone who knows what they are. But I have seen entire explorer engines with P heads on for $300 at the junk yard. So heads alone should be cheaper.
    Be sure they are GT40 and not GT40P. 3 stripes on the ends, not 4 stripes.
  6. maverick75
    They're 40 per head here, but most of the fox body guys pick them up quick. :(
  7. facelessnumber
    facelessnumber Drew Pittman
    Memphis, TN
    '71 Grabber
    And it's, what, '96 models that have the GT40 heads? Or is it '97?
  8. justin has a 74
    kentucky
    i believe its 96 and 97... most of the guys around here are chevy guys so i will see
  9. scooper77515
    I think it was mid-97 that they went to the P heads.
  10. mean_maverick
    yup, mid-'97 and up are "P" heads. found a '97 in a local yard once and thought i struck gold untill i seen the 4 lines :rolleyes: but i could have still bought the engine that was running/driving with 140K for $400
  11. mavdog71
    mavdog71 Member
    Moreno Valley, CA
    '71 Maverick Grabber
    Three strip ???????????????
    Four strip ????????????????
  12. mean_maverick
    Here's a pic of the end of a GT40 head and a GT40P.
    Attached Thumbnails[​IMG] [​IMG]
  13. scooper77515
    Check for the number of stripes on each end, then to verify, there is a P stamped on the Ps, and GT stamped on the GT40s. But if you can see the stripes, you will have it nailed.
    Cleaner heads in this pic for comparison.
  14. scooper77515
    Here is the main difference, and why the Ps don't work well with headers.
    Ps are on top. Spark plugs come almost straight out of the head. End up hitting the header tubes.
    You can see the GT stamp on the bottom one, and the P stamp is in the same place on the P heads.
  15. scooper77515
    Here is the driver side GT40P head with the header mocked up so you can see how the spark plugs DONT fit. In that second picture, there is no optical illusion or bad photo angle. Those spark plugs are touching the header right in the middle of the header tube.
