factory column shift linkage Question??
Discussion in 'Technical' started by maverick7072, Oct 31, 2013.
  1. maverick7072
    maverick7072 Member
    alabama
    1970-1972 mavericks
    i have a 72 grabber with headers and floor shifter and kinda want to put it back on the column.i found a guy who has a 4 dr 71 or 72 not sure which and it is a factory 302 car i need to know does the linkage fit all 302 s im not sure what model mine is i think its a 77 model 302 with a c-4 tranny ,i was trying to remember does the linkage slide in a hole somewhere on the side of the block or tranny bellhousing? pics or input would be helpful thanks guys
  2. Maverocket
    Maverocket Bob Williams
    Northwest
    69.5 Mav, 62 F100 unibody
    A stud screws into the block and the linkage slides onto it. I have a complete unit if you need it.
  3. maverick7072
    maverick7072 Member
    alabama
    1970-1972 mavericks
    do all 302 blocks have aplace on the block to mount this linkage cause im not sure where on the block to look for this
  4. Krazy Comet
    Blocks up to approx early '80s have the threaded boss on lower left side of block close to rear, if the engine is a late model it isn't there...
