Fan Shroud 6/V8
Discussion in 'Parts Interchange' started by Just Jim, Jun 5, 2004.
  1. Just Jim
    Just Jim Member
    So Cal
    '72 Comet '62 Falcon '58 Morris Minor
    The radiator in my '72 Comet 250/6 appears the same as a V8 radiator.Is the fan shroud the same for a 302 as the 250? If so,where do I get one for cheap?
  2. Craig Selvey
    It is not the same.
  3. Thack
    Thack vision advicator
    Moreno Valley Ca
    what makes them different?
  4. Just Jim
    Just Jim Member
    So Cal
    :confused: OK. So what's different and where would I get one?
  5. Wilbur Green
    Wilbur Green Member
    Plymouth, Ohio
    76Stallion, 762dr.
    I think the V8 ones are thicker or deeper how ever you want to say it would say the one on our fact. V8 car is at least 1 in. deeper than the 250 one we have would have to go check it out to be sure.
  6. igo1090
    igo1090 Member
    catonsville, md
    upper radiator hose inlet is larger on the v8 radiator. only difference i see. i have one of each right now. v8 doesn't appear any thicker than the 250/6 one.
  7. Wilbur Green
    Wilbur Green Member
    Plymouth, Ohio
    76Stallion, 762dr.
    Sorry i was talking about the fan shroud in my earler post not the radiators.
  8. Just Jim
    Just Jim Member
    So Cal
    Per my old Modine radiator catalog the 250 6 and 302 V8 use the same radiator which is the same as a 302 '70 Mustang. I was hoping the shrouds were the same also.
  9. Craig Selvey
    I seem to recall that the fan is not "centered" on a 250 like it is on a V-8.
