Fan Shrouds
Discussion in 'Technical' started by grabber71302, Jul 4, 2010.
  1. grabber71302
    grabber71302 Member
    alberta canada
    maverick grabber
    Is anyone out there using a radiator fan shroud? If so any aftermarket ones out there that are any good and not too expensive? I'm trying to get my Maverick to run a little cooler and the Maverick I took the V8 out of didn't have one.So...any thoughts?
    Kris
  2. PaulS
    Beg, borrow or buy one! they are really necessary on the V8 cars when idling in traffic.
  3. david_h_30170
    david_h_30170 Member
    Roopville,Ga
    1973 2 door v8
    I just bought a used one for my car. I am going to put it on my next off days, it has got to help, my car in traffic will get hot on these 90 degree days.
  4. brackenan
    brackenan Mr. Geek
    Parma, OH
    3D Maverick (all years), 2009 Ford Ranger XLT 4x4.
    Hey Kris,
    Check out autokrafters.com. It's been awhile since I've looked but I'm 99% positive they have the aftermarket fan shroud your looking for (y)
  5. ford84stepside
    ford84stepside Lone Wolf
    Berry Alabama
    1947 Lincoln Zephyr Coupe
    Not all of 'em. Mine never runs hot, even idling in traffic on 95 degree days. I am running a factory Ford flex fan without a shroud. I will probably need to add one when I get the AC system on it. But for now, it never gets above 190 degrees....
  6. mojo
    Fan Shroud
    I had the same setup as I see in ur gallery frm last year. I had the flex fan, stock rad and fac fan shroud. My car ran hot, hot in my view was when it
    wud go to 230'. It only got there when idling long periods in hot wx.
    I replaced all that stuff w/ alum rad and elec. fan; the most I've seen now is 210. I plan on reinstall AC nx yr also.
  7. justin has a 74
    kentucky
    Depends on how big your v8 is, my car does 195 at most in traffic, mabey its that 7 blade fan?
