Final word on 351w exhaust solution???
Discussion in 'General Maverick/Comet' started by Todd, Sep 20, 2013.
  1. Todd
    Todd Mavchanic
    New Jersey
    blue 70 two door
    Ive checked here and there, and there is no definitive answer to what headers / manifolds work on a 351.
    I dont know if anybody here remembers me or my car, but i finally got a windsor and its time to squeeze it in there. (thats what she said jokes aside)
  2. Moneymaker 1
    Panama City Florida
    A few small dents here and there on my Hooker 6901's and they fit, my Maverick is a 1972.
  3. franktf
    franktf Member
    Pinellas Park, FL
    72 Mercury Comet
    Crites are the only ones that are a direct fit....
  4. FishnRace
    FishnRace Jamie
    Solomon's Island, Maryland
    '72 2dr 351
    Crites. 1 3/4 individual tubes. No dings required.
    They give a pattern to cut out part of the shock tower and the metal pieces you need to weld in ... but you might as well do the full shock tower shave. :yup:
  5. Lzoesch
    Lzoesch Levi Zoesch
    Spokane, WA
    I have literally nothing but the frame rails. If I went to go for a 351 would I have MANY MANY options? or is it a notch have to be in the frame?
  6. CaptainComet
    The worst fitment problem with a 351W in a Mav/Comet is that the front two exhaust ports point straight out at the shock tower where the upper A-arms are.
    The second worst spot, pretty much with all headers, even for 302s is a lot of them tend to be close to the inboard limit of travel for the pitman arm.
    A floor shifter (if you have an automatic) is likely to be needed too.
    The headers for my swap, that was done in 1996, is used set of unknown brand (we suspect BlackJack ... got them from a friend). An inch was removed from each tube to narrow them, and they are far from optimal... two tubes leave the ports at a tight angle.
  7. dan gregory
    dan gregory Member
    chesapeake va
    1970 maverick
    Crites is the way to go unless you`re going to do a custom job,I`ll end up buying a set for my car.
