Fire breathing Carb!!
Discussion in 'General Maverick/Comet' started by SERE Guy, Jun 23, 2009.
  1. SERE Guy
    SERE Guy Member
    Fairchild AFB, WA
    '73 Mav w/ 302
    My car has been sitting for a few weeks and I went to fire it up, started rough as usual, gave it some gas to keep it idling high and then it launched fire out of the top of the carb (Carter AFB 4bbl, on a mild 302). I immediately killed the engine, and the fire stayed in the carb for a few seconds. What causes this, and how do I fix it? I plan on rebuilding the carb soon anyways, just so I can get more familiar with it, and try and solve the rough starting. Nothing damaged, but enough to make me immediately figure out where the closest extuingisher was.
  2. 408w-maverick
    408w-maverick Member
    Oklahoma City
    1974 Maverick 2 door
    Check the tightness on your Accelerator(Sp) Pump,my bro had that happen saturday at the track it cost me a shrt.
  3. madman21
    madman21 Beer is good
    Albuquerque, NM
    1976 2dr Mav 410ci
    Your timing may be a bit to advanced. Check it. On second thought, check and recheck your plugwires to ensure proper firing order as well.
  4. SERE Guy
    SERE Guy Member
    Fairchild AFB, WA
    '73 Mav w/ 302
    I'll check the firing order and timing again, but I set both of those awhile ago, and have never had this problem.
  5. madman21
    Albuquerque, NM
    1976 2dr Mav 410ci
    ewww
    I still say it is timing related.... Pull the distrib and check the gear for wear.
    Put a timing light on number 1# and see if the timing is jumping around.
  6. SERE Guy
    SERE Guy Member
    Fairchild AFB, WA
    '73 Mav w/ 302
    The gear is good, I'll throw a light on it next time I work on it and see whats up. Could moisture in the intake possibly cause this problem?
  7. madman21
    Albuquerque, NM
    1976 2dr Mav 410ci
    What are you getting at here??? lol
  8. SERE Guy
    SERE Guy Member
    Fairchild AFB, WA
    '73 Mav w/ 302
    There is a hole cut in my hood to clear the aircleaner. I had that hole covered, and it either ripped off, or someone removed it. The carb was still covered, but we had some pretty heavy rain, and a small amount of water could have entered.
  9. madman21
    Albuquerque, NM
    1976 2dr Mav 410ci
    I doubt that would cause the fire. Run the piss out of it and see if it acts better.
  10. SERE Guy
    SERE Guy Member
    Fairchild AFB, WA
    '73 Mav w/ 302
    That's my usual solution!
  11. Mavman72
    lean backfire...over rich condition/adv timing...Sticking intake valve.Water in the intake will cause the lean condition.It will cause an open intake valve to rust and stick in its guide momentarily...Long enough the have a dragon on your intake...Closest fire extinguisher should be in the passenger compartment of the car...Good luck!!
  12. SERE Guy
    SERE Guy Member
    Fairchild AFB, WA
    '73 Mav w/ 302
    Next payday a fire extinguisher will be going in the car for sure. Thanks for the help.
  13. Bryant
    i say it was a lean misfire. a combination of the motor being cold and the accelorator pump being out of adjustment or the diapram on the plunger may be hardened causing a lean moment when you put press on the throttle. what happens is a lean air fuel mixture burns really slow so there is still burning gas in the cylinder when the intake valve opens again. this lights the charge in the intake manifold and results in fire coming out the throat of the carb. if you left it running the vaccume will usually suck up the fire and put it out.
  14. darren
    Damn that was my guess. Rusty intake valve. Beat me again.:bowdown:
  15. 1973Maverick357
    Cookeville TN
    Next time it does that get the marshmellows out and make smores. Turn a bad situation into something good!
