Fitting a CD player in the Bezel
Discussion in 'Audio' started by rebelgt, Jul 21, 2007.
  1. rebelgt
    rebelgt Member
    Southeast Missouri
    1972 Comet GT
    I Was wondering if a new Kenwood will fit the AM bezel and bolt to the support in the back, It's a 72 comet. Thinking about a couple Boston Acoustics 6x9's in the back think these will sound o.k with no other speakers. other than the one in the front dash.
  2. Craig Selvey
    Yes....it will go in there. I have a Kenwood Deck in mine. You will need to cut the bezel obviously. You may need to bend the bracket in the back or use the piece of plumber's strap that comes with the radio (I can't remember what I did).
    Rear speakers should be good.
    Do a search on the front speaker install I did.
  3. mavmanerick
    royal city, washington
    my dad got me a thing used to mount a CB in anything and my pioneer just slid in after a little trimming and it went right in where the AM was..
  4. PAINTANK
    PAINTANK Cometosis Obsessivus
    South Central, North Carolina
    1973 Comet 2 dr
    I cut my bezel with t sawzall and kept filing on it until the "holster" fit pretty tight. Then I pressed out the tabs and installed the new deck THROUGH the hole. I had to run a self tapping 7/16 screw into the center of the back and put a threaded rod about 3 inches long in it secured with a nut at the base.
    A wingnut secures it in the factory brace under the dash.
    Install the bezel first...then the radio...then the wingnut.
  5. fastbackchaseca
    fastbackchaseca Lead Troublemaker
    Los Angeles
    '72 Comet, '56 F-100, and "88-0232"
    i just trimmed the bezel to fit the "holster", pushed out the tabs nice and tight, then slid a sony deck in. no bracing on the back, and it worked great for about 2 years, but somebody broke into the comet about a week ago and gripped my deck and broke the sh*t out of my bezel. anybody have a spare that stands to be trimmed?
  6. DonO
    DonO Member
    Xenia, Ohio
    1972 with mild 302
    I used a dremel tool to trim my bezel out. Deck fit in without any troubles
    whatsoever. We put in an Eclispe head unit and Polk Audio 6x9's in the
    back. Sounds pretty good to me. We'll put speakers in the front kick panels later. This was enough to get the boys some music. I told them
    to listen to the engine.....what I do....
  7. Jamie Miles
    Alto, GA
    I've had a few
    Here is my '72. I used a dremel to cut the bezel out also, and the factory support bracket just attached right to the rear of the head unit with a nut, no modifications.
    Pioneer head unit, Sony 6x9 speakers in the rear, 5x5's in the front kick panels. Sounds great to me. Only thing is, I usually have to keep the fade slightly to the front to make the music sound like it's "even" throughout the interior of the car. When it's set equal front to rear, it sounds like the rear speakers are louder then the front.
    The extra temp gauge was there temporarily, because I had yet to find a sending unit for the vintage Sun temp gauge.
