ok..help me out here.I have a 72 grabber that i'm trying to get floor boards for and i have not came across any so is there any other floor board off another car that will work like maybe a mustang or somthing?
haven't heard of any other cars the boards can be salvaged from. go get a mig and some sheet metal and make your own. thats what i've got to do.
Try Mustang I'll be fixing my rear floors with Mustang floors pans in the rear. Not sure what happened but both floors rotted at the seam. Obviously the ribbing doesn't match but the size and shape is close enough to be able to fit with some massaging. If the area is small enough just patch it. I have to small holes in the front and I figure a patch will do. Dan
You could cut some floorpans out of a rustfree car if you are in the southern or dry regions of the USA. Using sheetmetal and welding in with a mig is what I have done many many times. Just be sure you dont use galvanized sheetmetal and be sure to use a gauge of at least 18 gauge or better if you can find. Dan
