floor pan??
Discussion in 'General Maverick/Comet' started by uneven tugger, Aug 7, 2008.
  1. uneven tugger
    uneven tugger Member
    saskatchewan
    1976 maverick
    does any body know if anyone makes new floor pans or an alternate route??
    i just discovered how bad mine really are:cry:, and ive had no luck finding them.
    any help would be appericiated
    sorry if this is in the wrong place,
    thanks, jamie
  2. cometkurt!
    cometkurt! Member
    south paris maine
    well 65-66 floor pans will work if you work them into place.
  3. cometkurt!
    cometkurt! Member
    south paris maine
    sorry thats mustang floor pans.
  4. CaptainComet
  5. uneven tugger
    saskatchewan
    1976 maverick
    thanks for the info:thumbs2:
  6. 71mavkidd
    71mavkidd Member
    Kansas City, Kansas
    i think i was told that the mustang pans go in with just a little cutting around the edges :thumbs2:
  7. GrabberGT
    GrabberGT Chris
    Fort Worth Texas
    72 Grabber 302
    What are those plugs for? Does anyone actually expect to flood their car and have to use a drain to let the water out?
  8. markso125
    markso125 Member
    Lewiston Ut
    1972 maverick 2 door LDO
    I do on my CJ7 :thumbs2:
  9. Mavman72
    Jig locater holes.The holes properly locate the pan on a fixture so the rails can be welded on in the proper orientation during build/assembly.Afterward the holes are covered with a rubber plug or ametal plate and a couple sheet metal screws...mustang pans work... I put 65 mustang pans in my mav,trim the inboard edge off(tunnel side) untill it fits between the rocker and tunnel.The mustang had a wider pan than the mav.Also the pinch rail(lip at the rocker sideof the new pan)needs to bent upward if you want it to look correct, otherwise leave it alone and weld it to the rocker from under the car instead of inside the car.
  10. uneven tugger
    saskatchewan
    1976 maverick
    i just bought a bead roller and a shrinker strecher, im gonna try my hand at fabbing.......:confused: hpe it works out for me lol
